Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Leaking compressor revice guy said compressor is leaking freon and there's nothing to do. "it is an ex-fridge, stone dead, trash it" is there a fix for a leaking compressor? are there replacement compressors for Whirlpool fridges? tks.
  • Repairator Oct 02, 2008
    I have 1956 Westinghouse fridge vintage but recently the compressor stop and do not want to kick again. It was very hot & look like completly jammed. Can we replace it and if yes, I would like to replace it by something less noisy if it is possible.
    Thanks,
    f
    President:
  • 878 Answers
Jccam, just wondering if the service tech tapped into the system. This way he could tell whether or not you were low on charge or had a restriction in the system. You can replace the compresser on this model. It has to be done by a epa certified technician. Part number for the compressor kit is 2212192. You can see if it would be cost effecient at this link http://www.repairclinic.com/0080.asp Catriver post back.
Posted on Jan 19, 2007
Repairman says slow freon leak
If you are a generally lucky person it would probably be best to try and find the leak because the chances are I feel, somewhat greater the leak will be found where the compressor is joined and the pipework most subjected to vibration - fairly close to the compressor.
If the evaporator or condenser is leaking the fridge would be past economic repair.
If you aren't a lucky person it might be wise to make a different choice...
Sep 16, 2017 | Frigidaire PLRU1778ES Stainless Steel Side...
Refrigerator not cooling at all
Sounds like it needs more gas, and checking for leaks. If you have a leak tester, you can test that yourself, but topping it up has to be carried out by an authorised technician, sorry. Call your local fridge guy. Hope this helps :)
Sep 12, 2007 | Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
My fridge stopped cooling. the motor runs, but everything is warm. I have a bottom freezer Amana approx 4 yrs old. Is it worth fixing or should I buy a new one?
The compressor is working is a good thing ,you have leaked out some freon and it might be pricey to fix and I don't know with all the capturing of the gas ,recharging, only after they found the leak. Definitely get an estimate before you do anything ,but to answer you question is it worth it ,you'll have to weigh that out ,but a fridge is good for at least 10 to 15 years or longer. If not freon you could also have a thermostat problem which wont be so heavy on the wallet, get a guy out to diagnose it and see where you stand is all you can do.
Apr 02, 2011 | Amana Refrigerators
Wine fridge is leaking an oil substance... is this safe to use... or should it be fixed immediately?
If in the compressor or evaporator and condenser area, Yes this is serious and indicates a Freon leak that will damage your compressor, Sea Breeze
Nov 29, 2009 | Avanti WC3200BG Wine Cooler
I have a Maytag mtf2195aes model refrigerator. I paid some guy $160 to fix the defrost timer. It is not fixed. The problem is that the freezer part is building up water droplets at the top of it. The back...
It is not that defrost timer or the thermostat control if this part are faulty, your fridge may not run, your problem is in your fridge system
try to have this check:
1. see the pipes all around the back and inside the freezer (underneath its wall) see if there is a part oily (cause: possible leakage due to use of sharp pointed object that hit the pipes)
2. possible leak at the back pipes near compressor due to vibration
Result:
Under charge or loss of refriferant (freon gas)
Solution:
find the leak and fixed it, charging of freon
Nov 13, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
Refrigerator compressor overheating
Seems as if you have arefrigerant leak (or water vapor in the system) - both of which will trash the compressor in short order.
Time to take it to a pro who will put gauges on it and find out.
Sep 22, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
96 gmc k1500 4x4. a/c does not work
The 5.7l has a low pressure on off switch. if you freon is low it will not allow it to turn on. This is a way to protect the compressor. By jumping that compressor switch, it will turn on and blow hot because there is no freon AND NO COMPRESSOR OIL!!!! don't do it very long or you will trash your compressor if it is not already. Most vehicles these days have this safety feature.
Jul 03, 2009 | 1996 GMC Jimmy
Compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
May 10, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
268 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
