Question about Whirlpool LEN2000PW Dryer
The dyer works, heats up but the door keeps popping out and stop
Stopping the load from drying. I have checked the lint box and it is clear. I do not have it pushed up against the wall and the hose is free. Please help!!!
  • 116 Answers
REPL/ THERMAL FUSE LOCATED IN REAR (IF) LINT SCREEN ON TOP// OR LINT SCREEN INSIDE DRYER REMOVE METAL HOUSING WERE LINT SCREEN GOES INTO AND BEHIND THAT IS THERAML FUSE WHITE IN COLOR 2 RED WIRES CONNECT TOOOO......
Posted on Nov 30, 2008
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer taking long time to dry load
Sounds like an element issue, accessed from the back of the machine. Check with an appliance repair shop as to right element type.
Jan 08, 2014 | Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
GE DSXH43EAWW dryer stopped working mid cycle
unplug it,take it apart and check it out,you could have snapped the belt,there's a belt switch so if the belt breaks the dryer won't start,or if you haven't taken the dryer apart and cleaned it out and also the vent line you could have popped one of the t-stats,only way to tell is by checking them with a meter.the dyer should be cleaned out once a year ,if not the air can't move freely and one of the t-stats will pop as a safety,the dryer will run to hot and take out the thermal fuse or the high limit t-stat,if it's been taking longer to dry the clothes or if you see lint stuck to the bottom of the dryer door these are signs of bad air movement and the dryer and vent line needs to be cleaned out.
Dec 30, 2017 | GE DSXH43EAWW Electric Dryer
Dryer will not heat
1 Check the connection to heating element. See it is OK 2 Also check that lint filter screen is clear of lint. This also stops heating as there is no circulation of air. 3 As a matter of fact you must clear the filter of lint after every drying operation
Jan 22, 2010 | Whirlpool Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
My dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't heat up,runs no heat
IS YOUR BURNER COMING ON /IF NO REPLACE THE FUSE IN THE BACK ITS CALLED A OVER HEAT LIMIT FUSE IF THAT DOES NOT WORK REPLACE YOUR CERAMIC IGNITOR /1st UNPLUG THE DRYER /THEN UNSCREW TWO MOUNTING SCREWS THEN UNPLUG ONE ELECTRICAL CONNECTOR THESE ARE EASY REPAIRS YOU CAN DO IT /GET YOUR PARTS FROM A LOCAL PARTS SUPPLIER.
Jan 17, 2009 | Whirlpool Dryers
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Whirlpool LEN2000PW Dryer Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
