Question about LaCie (300951U) 500 GB Hard Drive
LaCie Hard Drive
Dear Master, My LaCie Hard Drive refuses to switch off the blue light. I do everything as I always did - eject it by dragging it into Trash, it seems to switch off but the blue button keeps burning. When I switch my computer there is more movement in the Hrd Drive anf then it seems to be completely off but the light is still on. I finally switched it off from the energy supply. How can I deal with it?
    Scholar:
  • 121 Answers
The hard drive has it's own power supply. If you look on the back of the external hard drive, there is a power button there to turn it off. It doesn't shut off just cause you disconnect it from the PC or turn the PC off.
Posted on Mar 23, 2007
SOURCE:
I put a mini disk in my macbook not knowing it would not load - now it will not eject
Be persistant-shake the F&^% out of it. Face it with the disk slot facing down and just shake it a few times. Worked for me.
Sep 15, 2009 | Computers & Internet
Yep - same problem
don't drag to the trash can , simply delete them
Jun 04, 2017 | LaCie External USB 2.0 500GB 7200 RPM 500...
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
[email protected]
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Lacie 2big Triple 2T - Raid 1 LED's blinking
Solved! After 17 hours of blinking, the status of the 3 leds is now to fixed blue. You just have to be patient...
Note that I had only put 1GB of data on the drive. I expect that the resynchronization time is not proportionnal to the amount of data on the disk!
Jun 07, 2008 | LaCie 1 TB 2big Spare Drive 301307 SATA...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Open Questions:
live 18OO8031069 PANDA tech support phone number issue usa Throughout the summer, building contractors were busy gutting the interior of the Barrett's building. Marketing PANDA banners tech.support are now phone.number draped on the front and back sides of the property alerting people that the Springhill Suites By Marriott will be Opening Summer 2020. City of Joliet economic development tech.support specialist Derek Conley told Joliet Patch on Wednesday: We're in contact with the developer and we're working with him. Conley said the Springhill Suites tech.support By Marriott stands to be another positive addition for the city's downtown. He envisions it will draw a lot of overflow traffic tech.support from the Harrah's Casino & Hotel, which is less than a block away. Spend a large portion of your day using PANDA TOLL FREE ? If you send and receive the phone majority of your PANDA TOLL FREE s on a number phone.number computer s support, keyboard shortcuts can tech save you tech.support hours of time. S support There are dozens of PANDA TOLL FREE keyboard shortcuts; presented here are customer the most useful to this PANDA TOLL FREE er. PANDA TOLL FREE splits its phone.number service keyboard shortcuts into two groups: those that are always on and those that need to be enabled. phone.number To see all of the keyboard short tech.support cuts that PANDA TOLL FREE offers, hit Shift-? when viewing your PANDA TOLL FREE inbox. Here are my favorites. Always-on PANDA TOLL FREE number keyboard shortcuts
Sep 19, 2019 | Panda Computers & Internet
live 18OO8031069 KASPERSKY tech support phone number issue usa Throughout the summer, building contractors were busy gutting the interior of the Barrett's building. Marketing KASPERSKY banners tech.support are now phone.number draped on the front and back sides of the property alerting people that the Springhill Suites By Marriott will be Opening Summer 2020. City of Joliet economic development tech.support specialist Derek Conley told Joliet Patch on Wednesday: We're in contact with the developer and we're working with him. Conley said the Springhill Suites tech.support By Marriott stands to be another positive addition for the city's downtown. He envisions it will draw a lot of overflow traffic tech.support from the Harrah's Casino & Hotel, which is less than a block away. Spend a large portion of your day using KASPERSKY TOLL FREE ? If you send and receive the phone majority of your KASPERSKY TOLL FREE s on a number phone.number computer s support, keyboard shortcuts can tech save you tech.support hours of time. S support There are dozens of KASPERSKY TOLL FREE keyboard shortcuts; presented here are customer the most useful to this KASPERSKY TOLL FREE er. KASPERSKY TOLL FREE splits its phone.number service keyboard shortcuts into two groups: those that are always on and those that need to be enabled. phone.number To see all of the keyboard short tech.support cuts that KASPERSKY TOLL FREE offers, hit Shift-? when viewing your KASPERSKY TOLL FREE inbox. Here are my favorites. Always-on KASPERSKY TOLL FREE number keyboard shortcuts
Sep 19, 2019 | The Computers & Internet
See all LaCie (300951U) 500 GB Hard Drive Questions
LaCie (300951U) 500 GB Hard Drive Logo
258 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
