Have used compatible ink before on my dx3850 epson. have some more cartridges and it wont print anything
    Sergeant:
  • 217 Answers
The head in which the cartridges r inserted is now blocked due to ink dried up in the holes from where the ink comes out.a common epson printer problem.now the whole head needs to be replaced.they r avaiable in the maket just get 1 from your neares epson servi center.or nearest epson printer dealer.
Posted on Nov 29, 2008
Epson stylus dx3850 ink saying empy when full and wont print
Hi
Try turning the printer off and disconnecting it from power completely.
Check for paper jams on the machine.
Clear any print queues.
Mar 02, 2012 | Epson Office Equipment & Supplies
I have replaced all the ink cartridges, but it still says they are empty. It won't print anything. what do i do?
are these original ink cartridges? sometimes when you use compatible inks these happens. get some original inks in and check if it still does it. if you do have original inks and still get this problem the head may have a problem. you will need to have it checked at epson. if the original ink works, try to put the compatibles in, this solves the problem most of the time for compatibles.
Jun 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
My Epson stylus color 740 printer was showing replace inks so i did and colour ink is find but anything that is in black wont print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
Epson CX3900 says all cartridges empty but not true
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
I REPLACED MY INK IN THE EPSON NX110 PRINTER
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if any of the cartridges are empty.
Jan 31, 2010 | Epson Stylus NX115 All-In-One InkJet...
My printer was printing fine, iloaded new ink
Epson does not like Generic/Compatible Cartridges
MUST BE GENUINE
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Put back in Genuine Cartridges, and see if it works. This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 04, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Wont print black or yellow ink
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
Dec 16, 2009 | Epson Stylus C64 InkJet Printer
My sx200 wont accept compatable ink cartridges
If you are using refilled ink with epson it can cause the print head to go bad. Epson is very picking when it comes to their ink. I would suggest using there ink
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
Using non-OEM ink
There are epson ink compatible cartridges in the market that are less expensive but have good quality. Please look for other compatible brands which good quality guaranteed, try those compatible brands which are more popular.
Apr 01, 2008 | Epson (C31C411016) Printer
176 people viewed this question
jasbo
jasbo
