Question about Heavy Machinery
Chipper Shredder Vacuum won't start
I have a Troy Bilt Chipper Shredder Vacuum (CSV 060 with a 5.5 HP Briggs & STratton engine). I have been using it with no problems for 3 or 4 years. Today the engine seems to be stuck. I can't even pull the starting cord. I looked and the blades seem not to have any obstruction, so I'm sure it is the engine. I know I haven't added oil in a while, and I put some, but I don't know if that's the lack of oil is the cause.
  • oc918 Dec 04, 2008
    It was low in oil. After looking at the comments on a video in YouTube, I took out the spark plug, pour a little oil in the cylinder, moved the blades by hand (well, I used a stick), and then pulled the starter rope several times. When I tried to start it again, it did start, belched a lot of smoke once, ran for 5 seconds, and then died again. I am hopeful, because the engine is no longer stuck. I read the manual (I should have done that first!), and realized I've not given the shredder vac any maintenance. I bought a new spark plug and a new air filter. I will clean the machine, put clean oil, cross my fingers, and try again. That will happen this weekend, so I can't report anything now. I'll be happy to get any suggestions. I do think now it was the lack of oil.
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    how low was it on oil? do you check/change the oil often? is there any play at all with the blade or flywheel?
    New Friend:
  • 3 Answers
This is indeed caused by the problem of lack of oil, but should not be much problem. Frequently used machines require maintenance. You can refer to the following URL: http://educationcare.in/en-machine/3306.html
Posted on May 09, 2017
    Habit-Forming:
    New Friend:
  • 25 Answers
3 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: Describe your Troy Troy-Bilt® Briggs and
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Posted on Jun 26, 2009
rwvanlue
  • 486 Answers
SOURCE: Misplaced operation manual for Troy-Bilt Briggs
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Posted on Nov 08, 2009
How to remove tire on Troy Bilt chipper shredder
there is either a clip or a cotter pin that needs removed , then slide the wheel off .
Nov 19, 2013 | Troy-Bilt® Briggs and Stratton Chipper
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Oo.comI need a motor diagram for Briggs and Stratton 5HP shredder chipper
Get the model and type number off the engine and you can go to a website like partstree.com or others and with the brand and the model and type number you can get diagrams of the engine.
I hope this is helpful for you.
Aug 13, 2011 | Troy-Bilt® Briggs and Stratton Chipper
Where can I get an owner's manual for a Troy Bilt Super Tomahawk chipper
Here: http://www.brentchalmers.com/
Keep all of those fingers out of the shredder!
Hope this helps, if so pls leave feedback, if not let me know!
Jan 25, 2010 | Troy-Bilt® Briggs and Stratton Chipper
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Drive belt and a manual for 8 hp tomahawk chipper shredder
did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
Jun 08, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
No where to go
Try ebay...I have found a lot of parts for my troy bilt chipper shredder on there. Sometimes you can also find a local dealer who might have parts laying around also.
Apr 20, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Pulley size on Troybuilt Super Tomahock Chipper Shredder
Yes I solved my problem and it was rather easy, I should have thought of it before I wrote, My son ia a Mechanic for Hertz Rentals, I asked him. Thank You for your assiatance. R. Todd
Mar 25, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Heavy Machinery Logo
899 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
