Question about Refrigerators
Refrigerator keeps running constantly and freezin on refrigerator side (too cold)
  • 1 more comment
  • jose_albe949 Nov 29, 2008
    Thanks for the info is this a replaceable part. part of PCB or one off three sensors two on top one on bottom
    sensor 1 top between room temp 12K ohm to low 30 23k ohm
    sensor 2 botoom same
    sensor 3 top temp switch (continuity OK)
    Maybe something in PCB
    Mine is an LG BR-T466GVH
    Thanks I'll quote the board
  • 121 Answers
Sounds like the cold control is bad
Posted on Nov 29, 2008
  • sdmc73
    sdmc73 Nov 29, 2008
    the sensors can be check with a metter the resistance changes with temp
  • sdmc73
    sdmc73 Nov 29, 2008
    that board is costly but it sounds like it could be
Refrigerator noisy and runs almost constantly
If the noise is coming from the back it could be the Fan or the compressor_ is the unit keeping the food cold enough? If not could be a bad compressor with low refrigerant or bad internal pistons-either way costly to repair- maybe be cheaper to buy a new fridge_ how old is it and is it under warranty?
Oct 25, 2016 | Kenmore Refrigerators
Refrigerator and freezer not cooling
Hi Kirk Huggins - Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the refrigerator could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor or evaporate fan. Contact a professional to accurately pinpoint any potentially more serious issues and to assist with the repairs.
Jan 27, 2013 | Frigidaire FRS26R4A Side by Side...
I have a LG LRSC26940TT and the cooling temp. keeps saying error and the freezer is not cold. i unplugged it and when i plugged it back in it worked but then i put food in the freezer n it said error...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | LG LRSC26940TT 36" Side-by-Side...
Nofunciona el compresor
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 05, 2010 | LG LRSC26940ST 36" Side-by-Side...
Freezer runs constantly, refrigerator not cold freezer ices up, does not defrost
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 03, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Kenmore model 58644 frezzer not freezin and fridge not getin cold
check condenser fan motor for obstruction or failure
Jan 27, 2009 | Refrigerators
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
