Question about Canon PIXMA MP460 All-In-One InkJet Printer
I can't get the printer to go on standby
Can't get the printer to go on stadby. The ink cartridges are not in the middle where I can change them.
    Sergeant:
  • 217 Answers
Unplug the printer and press the ON BUTTON then insert the plug.again press the ON button 1 more time.it will start moving and come to the position.
Posted on Nov 29, 2008
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
When I open the top to replace the ink cartridge, the ink does not go to the middle so I can remove the old cartridge.
Turn the printer on before changing the ink cartridge. The mechanism will only go to the middle if the printer is turned on.
Mar 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I change the ink cartigages?
Here's an article on How to Install Ink Cartridges in Lexmark X4200 Series All-In-One's. Just follow the instructions on this link: http://bit.ly/c1bGkM.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Aug 20, 2010 | Lexmark X4270 All-In-One InkJet Printer
How do you change the ink cartridges?
Here's an article in the Lexmark website on How to Install Ink Cartridges in Lexmark X4200 Series All-In-One's. Just go to this link: http://bit.ly/bMEdoT. Follow the instructions.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks
May 20, 2010 | Lexmark X4270 All-In-One InkJet Printer
How do i change the ink on canon mx330?
They are not in the middle as shown in the manual. I still can't find them. God! this printer is only that big and I spent three days looking at every possible corners and gaps and still can't see where the ink cartridges are. Will not buy this Canon printer again.
Nov 02, 2009 | Canon PIXMA MX330 Multifunction InkJet...
How to replace a new set of ink
If ink cartridge show red light for empty ink cartridge Just press the cartridge will come at standby those cartridge is empty ; just replace it.
If not empty you want to change
Press ink button ..... don't leave until your carriage unit not come at the replacement position
First Black will come and next color will come and after pressing ink cartridge it initialized and it will be ready /
Thanks
Oct 28, 2009 | Epson Stylus C20SX InkJet Printer
I just want to change the black ink cartridge - how do i do it
I needed to know that to get to the ink cartridges the MP240 had to be switched ON before lifting up the whole scanner bed from the front.The ink cartridges will then slide to the middle and can be clicked out and a new ones clicked back in.
Aug 07, 2009 | Canon PIXMA MP240 All-In-One InkJet...
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
