Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
MY BOOK 1 TERA is not responding, only one circle is on in blue
One of a sudden my hard drive is not responding. It is not recognized by any PC. When I turn it on, you can hear like 3 clicks two or three times. Regarding the the two blue circles you have in front, only one (the external circle) is on in blue. The other one is off. What can I do to fix it? Do I have any chance? I want to get my information there!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the clicking sound could possibly be the head slapping against its stop inside the actual hard drive. This would then indicate a hardware problem. You of course could try the external drive on another computer, verify that all connections are good & tight and allow the hard drive to rest for a while before trying it again. Worst case scenario is removing the hard drive from the enclosure and trying data recovery while that HD (hard drive) is attached physically/internally to a computer and not through USB interface.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 229 Answers
The clicks you hear are the device trying to read the hard drive. It sounds like it has been damaged somehow. Try a hard boot. disconnect from power for at least a half hour and then plug it back in. Sometimes the device will reboot itself and work. If you are successful you need to seriously consider backing up your material and getting a new external hard drive. This one is about kapoot if not already. Good Luck
    Genius:
  • 1,550 Answers
No it is damaged and you cant repair it .
You need to buy another one .
Regarding the circles the hard drive is not working (not powering up)
So the inner circle is OFF
  • 13,433 Answers
Check your warranty, if the drive clicks constantly then its a hardware fault or in some cases the powersupply may have failed if the drive uses one.
    Genius:
  • 3,422 Answers
HI,
Please try connecting your hard drive to another PC/laptop and let me know if it is recognized or not.
  • Priya darshan Nov 29, 2008
    Try
    connecting your HD to another USB port. Using one port all the time
    to connect and disconnect USB items a port can develop a range of files
    associated with configuring the USB connection. Some of these files
    might actually have been from your HD connected before, or some of
    these configurations could be from other USB items you connect to this
    port. Changing ports can often lead to an immediate good connection
    simply because ther are no conflicting configuration files. If this
    does not solve your problem, we can now entertain the next process to
    try.
    THIS
    IS A BIG ONE. This is the last thing to do. Before you try this
    process, please complete a full back up of your system. This is
    important as the next step can have side effects you did not entirely
    expect. AND Second, you might need your XP Install Disk (not in all
    cases). What this process is about is renewing all hardware/software
    configurations relating to USB connections.
    Here is what you do:
    1. Right click MY COMPUTER
    2. Select PROPERTIES
    3. Select HARDWARE
    4. Select DEVICE MANAGER
    5. Select UNIVERSAL SERIAL BUS CONTROLLERS
    6. Right click on each USB CONTROLLER and select Uninstall
    7. Uninstall all entries
    8. Reboot your computer
    9. As your computer re-boots it will reinstall all USB connections it detects
    THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB HD.
    If
    these suggestions are implemented and you are still have connection
    difficulties with your computer, there are several other things to try.
    If you have another XP Computer you should try connecting your HD
    to another computer to see if the problem is a HD problem or not.
    If it still has this problem with the next computer, it is a
    fault of the HD
    IF YOU HAVE COMPLETED ALL the above
    mentioned and still have a problem, you should next get this repaired or replaced.
    If you have windows vista,same steps are to be followed.
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I plugged my wd into my dish dvr it formated, decieded i did not wanna use my 1 tera on this wanna do a smaller drive how do i reformat my wd external hard drive so that i may use it for computer stuff?
If your PC will not recognize the drive now, you will have to use an external formatter program. If it will, thenclick on the drive letter of the drive and choose format from the options menu.
Nov 13, 2010 | Western Digital My Passport Essential...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My computer doesn't recognize the WD book
Several things can be done. You can try DIY software, assuming you have enough free space on your computer and it's a minor failure this may work.
Second, the enclosure itself may be failing, you can try moving the drive into a new enclosure, to do this take the drive to a PC shop and ask the technicians to test the hard drive in a new enclosure. If the drive works in the new enclosure you're set, if not move on to the next step.
Finally if you don't want the risks of the DIY method and the new enclosure fails, reply back with your location(Country, State and City) and I will be happy to refer you to a pro near you who can assist you with the process of recovering your files.
Hope this helps FixYa,
Chris
Oct 26, 2009 | Western Digital My Book Essential Edition...
Western Digital MyBook suddenly no more responding. It worked perfectly over years, but one morning I entered the office, and the blue rings were on. But iTunes didn't play any songs, the library is...
You may be able to remove the hard drive manually and try another USB adapter to access it on your computer.
Might be pootched though.
Rule of thumb is to never save your files to only 1 source. Its not a question of if a hard drive is going to fail but WHEN.
Sep 26, 2009 | Western Digital 500GB MyBook Office...
While updating firmware on my WD My Book (WD10000C033-000) the drive suddenly stopped responding, and no matter what I try, it will not turn back on. When you plug power in, NOTHING happens, not even...
There are 2 things you can try:
  1. Go to My Computer and click on Tools/Map Network Drive and try to assign a new drive letter to the external; if successful, you should be able to access the drive; if unsuccessful:
  2. Click on the link below and install the program (it's freeware) Run the program and it will recover all "lost data" even on the external drive. After recovering the data, you may need to reformat the drive to make it workable on your machine again.
PC Inspector Data Recovery
Sep 01, 2009 | Computers & Internet
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Jun 09, 2009 | Western Digital 500GB My Book World...
Iomega 500 GB hard drive has stopped working
new power adapter. Had same problem with a my book. I have two of them, and one is a tera other a 500gig. when I switched cords they both worked fine.
May 27, 2009 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
How to recover WD passport250 Data
hi...if you want to see again the files on the external hard drive i suggest you make to re-install the windows or repairs the windows you`re using or try to update the mother board drivers..thank you...^_^
May 09, 2009 | Computers & Internet
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
