Question about Sharp (RLMPF0014CEZZ) Projector Lamp for XV-H30U, XV-H30U, XV-H30
Sharp XV-H30U Projector No Video
I have recently recieved this projector for free, but when it is turned on, all you get is a "white screen," no signal. Does anyone know how to fix this?
En la parte trasera del proyector tiene un grupo de conectores de video, conecte la señal de video a proyectar en "in 1" o en "in 2" y posteriormente levante la tapa de acceso a los controles ubicada encima al lado izquierdo y con el boton "video in select" seleccione video 1 o video 2 segun haya conectado la señal atras, luego con el enfoque manual del lente obtenga el enfoque adecuado. Espero haber servido.
Posted on Aug 01, 2009
SOURCE:
No image! My input signal is recognized, but nothing will display.
check laptop output settings my laptop uses f4 with the function key to switch the output mode your laptop may have a similar setting from Laptop only to Dual Screen to Composite screens.
Jul 08, 2015 | Christie RoadRunner L6 Multimedia...
Dark Spot on Lower left screen
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD150-200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 03, 2014 | Acer H5360 3D DLP Projector
Hello i have a LOGIX x19/17-usb television, the screen is completely white but i can still here tv sound. This has happened before and a wire was replaced under warranty, however on recieving the tv back...
LCD noy getting video signals. It maybe contact resistance problem, Or you may try different inputs and swich on TV? Switching inputs may get the TV signals thru the lcd?
Jan 03, 2011 | Televison & Video
E400 black screen with white dots
Hi, I am having the same problem right now with my BenQ projector! Did you manage to fix your issue?
Feb 18, 2009 | IBM E400 Multimedia Projector
Panasonic PT-L701e - colour fault, blacks are blue with lines
Can you connect a computer (vga) signal to this projector? I'd like to know what your "white" computer screen does on the projector....example, Excel spreadsheet....
I am leaning towards these problems, a bad video card...or worse delamination of one of your LCD panels and possible polarizer burn in the optical engine.
Best Regards,
Steve
Dec 11, 2008 | Panasonic ET-LA702 Projector Lamp for...
PJ458D Displays Multiple Lines and scrambled picture
White noise-the image you get when you turn your television to a channel that isn't receiving a signal. Sorry, this is an old term for on-air televisions. Its kinda the same image you get when your DirecTV signal gets scrambled during a thunderstorm.
Sep 20, 2008 | ViewSonic PJ458D Multimedia Projector
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Black bar on bottom of image when i turn on projector
Projector Doctor in San Diego can do PS and board level repairs on this projector.
Feb 20, 2007 | Toshiba TDP P4 Multimedia Projector
317 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
