Question about HP Office Equipment & Supplies
After replacing my yellow ink cartridge it is still telling me that I need to replace it.
    President:
  • 2,110 Answers
Try to check wheather it is properly connected or not...
Posted on Nov 29, 2008
My MX 700 won't print. I replaced thje yellow and magenta cartridges an dit keeps telling me that the yellow still needs to be replaced
Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place. reseat it again then turn off the power then restarts most of the time this fix the issue
Dec 02, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Replace yellow ink but machine says no cartridge
When you get the "no cartridge" message it's because one of the sensors does not recognize ink in one of the cartridges.
First open the ink cover and read the LCD screen.
The LCD will tell you which cartridge is having a problem. You should change which ever cartridge is telling you there is a problem.
If the LCD says there is a problem witht he yellow (which you just changed) then follow the below steps.
1. Unplug the power to the printer.
2. Remove all 4 ink cartridges.
3. Close the ink cover with all the inks removed.
4. Plug the power back in.
5. When the LCD says "ink empty" you will reinstall all 4 ink cartridges.
Thank you,
Mar 29, 2010 | Brother MultiFunction Center MFC-440CN...
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
I have replaced all cartridges-Black, yellow,blue,cyan ; however, print message indicates replace yellow.
The head of the printer may be defective that's why the cartridge is not detected by the printer.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
27 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
