Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
  • Anonymous Mar 22, 2014
    May have punched in too many selections at one time. Reset button is not resetting even though it has power. reset button bad? memory board bad?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Posted on Jun 25, 2009
Wurlitzer 1015 jukebox
It is the arm sensor for the end of the disk.
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rock ola 460
Contact the Guy at American Restoration in Las Vegas NV, he rebuilds these.
Jul 13, 2017 | Audio Players & Recorders
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
KEEP ON PLAYING THE SAME RECORD
If it is a simplex mechanism then when a selection is made a small 'pin' pops up. The machine then sets going and an arm sweeps round until it bumps into the pin and then goes into the play cycle. The arm is stuck up against the pin because it hasn't reset and so it plays over and over.
Have a look on the right hand side, below the mechanism base board and you will see the circular solenoid selection assembly and the arm that sweeps round. Press the pin back down that is against the sweep arm and it should start working.
Dave F.
Oct 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
The arm on my 1015 Werlitzer will not reset itself.
THE GEARS OR OUT OF LUBRICATION.
LUBRICATE WITH WHITE LUBE GREACE.
THEN TURN THE KNOB ON THE GRIPER ARM
TO RAISE, AND LOWER THE ARM. THE ARM IS STUCK.
DOCTOR FIX IT
IN-HOME JUKEBOX REPAIR
6362273300
BALLWIN MO.
Feb 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
JUKEBOX WAS SHUT OFF WITHOUT REJECTING ALL THE RECORDS.
What exactly do you mean by "shut off before all the 45's were rejected" ? The mech only load one record at a time, either from the left or right side of the carousel. If the power was shut off before a record unloaded from the turntable, you can manually return the mech to the start position. Do this by getting in to the back of the juke. on the upper right, near the top of the deck, there is a motor. There should be a little white gear coming from the bottom of it. I am assuming if you look in the middle of the mech, you will see a cam with a lobe on one side of it. Turning the white gear will advance the mech adn turn the cam counter clockwise. As the lobe on the cam nears the front of the mech, the record lifting arms should pull down clear of the carousel and return the record to the carousel. Stop turning the gear when the lobe of the cam has driven the lifting arms downward. Inspect your pin bank and push down any "popped" pins. This will prevent the juke from trying to start when you turn it back on.
Hope this helps
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
368 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
