Question about Whirlpool Duet GHW9150P Front Load Washer
WHirlpool Duet Washer
Our washing machine is 3+ years old and recently the washer has on several occasions filled itself fully or partially with water when the machine was idle. The machine otherwise functions normally and these incidents occur after the machine has not been in use for several days. On one occasion, the machine failed to keep the front door locked allowing it to open with resulting water spillage with a surprise machine full of water? It's gotta be some sort of electronic malfunction I would assume to allow for random water filling when the machine is powered down and idle. Anyone have a clue? Eaily repaired?
  • Sven Cederwall Jan 24, 2007
    Catriver, thanks for the prompt response.
    After looking at a parts list for the duet I suspected it might be the intake valve but frankly assumed I would be having troubles during operation as well.
    Anyway, my local parts guy had to order the part so I could not get to the repair for 2-3 days. I just switched it out and you were right, the repair is pretty simple even for a mechanic wannabe who knows enough to be dangerous. Mine is on a pedestal so it's tougher to get behind it but I managed. We'll see if that cures my problem.
    One comment - Whirlpool uses a Torx head screw to secure the valve to the back of the washer body. Very cute - fortunately I have a nice collection of tools as I suspect a Torx screwdriver or driver is not a common must have tool for the average Joe. What a bunch of dopes - I hate when they do stuff like that.
    Anyway thanks a million - my parts guy also concurred with your diagnosis.
    Swede
    President:
  • 878 Answers
Swede, you need to replace the water inlet valve. Part number 8181694. This is an easy fix. Just remove the 3 screws that are in back holding the top on. Slide the top back and you will see the valve. Couple of screws and a clamp and it will come right off. Catriver..post back.
Posted on Jan 19, 2007
Just ordered the part for my Duet washer....will advise how it goes.
Posted on Aug 21, 2008
Washer fills overnight (GHW9400PW4)
a bad water inlet valve try unplugging machine and see if it still does it? if it doesnt do it when unplugged then u have an electrical signal problem from eiither control board or timer if it keeps doing it when unplugged its ur water inlet valve
Jul 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer slowly fills with water when not in use. I
I have the same problem. The only problem that I have is not knowing how much water will eventually go into the tub. It takes about 4 or 5 days to accumulate about a gallon. I called the Whirlpool service center and the woman said they recomend turning the water off after each use-I think this is ridiculous. If going away on vaca maybe. Rob
May 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
3,022 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
