Question about Maytag Dryers
One of the drum baffle has come unscrewed. How do I take the top of dryer off to reach the drum
  • 78 Answers
What model of the Dryer you have?
Posted on Nov 29, 2008
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
Sdg109wf when running it like rattling sound coming out. what do i\I have to do?
You may have to find a way to identify the location of the sound; type of sound..metal on metal, like something is loose?
The only thing I know that rattles in a dryer is if something got into the baffles/the wings on the inside of the drum.
If this is the case you have to open the top of the drum and unscrew the one baffle that that has something loose in it.
Oct 18, 2013 | Dryers
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside paddle fell off
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top.Rotate the drum around and reach inside the drum. Re-attach that baffle.
Apr 09, 2009 | Whirlpool LER5636P Electric Dryer
Fins fell off tumbler on Whirlpool Ultimate II dryer
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Jan 01, 2009 | Whirlpool Dryers
Remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Aug 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore gas dryer model 11070812990
Take a flat-blade screw driver and stick it in the seam between the top cover and front panel at one corner and pry up. The top panel will pop up from the catch - then do the same for the other front corner.
You can then tilt the top up towards the back of the dryer because there are hinges in the back. Spin the drum to where the holes for the baffle are and screw the baffle back on. If you are missing the screws, they probably fell to the bottom inside.
You can take off the front by unscrewing the two screws that hold the top of the front panel to the outside panels. Once those are off, just lift the front panel straight up and pull away. There are two holders towards the bottom that the front panel slides into.
Once the front is off you should be able to find the screws below.
Good luck. . .
Mar 24, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
35 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
