Question about Intel D101GGC Motherboard
Sometimes my computer restarts suddenly.
I have core 2 duo processor and Intel d102ggc2 motherboard. Sometimes my computer restarts suddenly without any hardware fault, and some time being hanged by stop error. please response and solve this problems
This problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Posted on Jan 02, 2009
  • 781 Answers
Probably overheating
remove side of case clean all fans remove fan from heatsink do NOT remove heatsink it get stuck by paste. clean vanes replace fan
use stiff brush and vacuum clean to clean outside of power supply
Vacuum inside case cleaning all vent holes
replace case side and boot computer
Posted on Nov 29, 2008
I was looking to upgrade my computer processor
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
Jan 28, 2012 | HP Computers & Internet
My motherboard model is D101GGC Is this support CORE 2 DUO E4600 processor
This motherboard model will not support Core 2 Duo E4600.
It will support only.
1.Intel Pentium D Processor.
2.Intel Pentium 4 Processor.
3.Intel Celeron D Processor.
Thanks for using FixYa.
Jun 03, 2011 | Intel D101GGC Motherboard
Im plannin 2 upgrade my RAM..My mother board(Essential series D102Ggc2) supports DDR2 800...my processor is Pentium D 820+ ...my query is: DDR2 800 is supported by Mother board but is it supported by my...
Your motherboard has the follwing memory support : DDR2 533/400 SDRAM 2 slots, Single-channel (2GB2 Max). As long as it is supported by your motherboard there would be no problem since your processor is also supported by the motherboard.
Please refer to the follwoing links from Intel:
1. http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/cs-026580.htm
2. http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
3.http://cip-origin.intel.com/cd/channel/reseller/apac/eng/products/desktop/bdb/d102ggc2/feature/index.htm
Mar 06, 2011 | Intel Pentium D 820 Smithfield 800MHz FSB...
Restarting problem
Not quite sure what you mean, but if it is that the computer restarts suddenly while booting up, it could be indicative of a problem with the RAM. try taking one of the sticks out of its slot, and if it still doesn't work swap it with the other stick. Good luck!
Mar 01, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
I have motherboard intel grand county 2 d102ggc2, and my question are i can set on it procecor dual core Or core 2 do, if yes please let me how. my procesesor now it's intel pentuim 4 3000 mhz thanks
No, you can't. The socket of the pentium 4 it's diferent from the socket of the Dual Core/Core 2 Duo. You need to purchage a new motherboard for this processors.
Feb 24, 2011 | Computers & Internet
HI I AM PRASAD.SINCE 2007 I USE D102GGC2 BOARD ALONG WITH CELRONE CORE 2 DUO PROCEESSOR.SINCE THE FIRST TIME I GET MEMORY LESS THAN 64MB ACTUALY.MEANS THAT IF I INSERT A 512MB RAM I GET ONLY 448MB...
hi prasad, u r getting a lesser memory because you motherboard consumes 64mb for its shared usage... this is common, certain motherboards comes with a builtin shared memory, some does not...
right now the SMPS on your computer might have gone bad, u can check with a different SMPS... Sometimes even the board might have shorted, in this case you can service ur board... it may costs around Rs.400
Aug 04, 2010 | Intel D102GGC2 Motherboard
CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Sep 06, 2009 | Intel Computers & Internet
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
Intel D101GGC Motherboard Logo
182 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
