Hi, When I print a letter on my ML-1430 Samsung printer, it leaves a vertical streak of toner at the very edge on one side of the paper. Do I need to clean it, and if so, how do I clean it? I'm thinking I need to remove the cartridge, but then I'm not sure what to do after that. Thank you for your help, Susanne
    Sergeant:
  • 217 Answers
The cartridge needs to be refilled and the waste tonner collected in the cartridge needs to removed.it can be done at any local cartridge refilling store.
Posted on Nov 29, 2008
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
How can I print an envelop on a Samsung ML 1430
Put an envelope in the sheet feeder, and use "letters and mailings" option in MS word or whatever program you're using
Jul 26, 2009 | Office Equipment & Supplies
Paper jammimg in our ML 1430 Laser Printer
clean the roller opening the door at the backside of printer...................and if u want our technician support contract us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Samsung ML 1430 Laser Printer
Black streaks on paper on samsung ml 2150 laser printer
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Apr 28, 2009 | Samsung ML-2510 Laser Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
White Streaks down left side of page.
Shake the toner hard and try again. It should work.
Dec 11, 2007 | Samsung ML 2010 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
75 people viewed this question
jasbo
jasbo
