I began having problems with my monitor about 4 months ago. I turned the monitor off and it stayed bright white and did not go black. The entire screen was a big white light!! I had to leave the monitor turned on because it lit up the entire room. Several weeks later, I tried to turn it off again, and it turned off correctly. I noticed in the top left corner, the screen was flickering. The screen display was still pretty good. It continued, so I decided to turn it off. It went off fine, but will not come back on. The green power light seems to flash 4 times, then short break, 4 times, break, etc. There is no type sound coming from the LCD. Any idea what the problem may be.
-   ve a sync master 19 inch monitor 910mp doing exactly the same. I am assuming its the psu up the duff, anyone know a fix 4 this.
-   paul_bat
Jan 28, 2008
-   the green light is flashing on my dell flat screen montor wont come on-   Guest
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
constant blinking of osd lock and other menu options.besides contrast and brightnessgets adjusted on...
(More)
CONSTANT blinking of OSD lock and other menu options.besides contrast and brightnessgets adjusted on its own.how to solve this?
When i refresh my computer the desktop turns black for sec's and again comes to normal. When i...
(More)
When i refresh my computer the desktop turns black for sec's and again comes to normal. When i restart the blank screen appears with desktop items and after 2-3 sec the wallpapers appears. When i drag the folder in the desktop it shows the dragging of the folder like: many folders behind the original and when dragging done it disappears. Kind of weird problem cannot explain this in more detail. :) Using AVG anti virus and no virus threats seen....using C cleaner and other system scanner no threats found. 2GB ram with minimum XP softwares on the computer.
