Question about Acer Aspire 5100 Notebook
My Acer 5100 series problem is that I turn it on, i get the fan to come on, the cpu has power, but I get nothing on my screen or anything else to work on it. There are no beeps so I can't use beep codes from the BIOS to figure it out myself.
  • slimatic Dec 01, 2008
    I have the exact same issue. Prior to that I was having hard disk issues and occasionally grey horizontal and vertical lines will appear on the screen.
My acer Aspire One has the same probleme describe above when you turn on it we will see the green light on the switch and we can hear the fan start and anything else happening no boot no disk activities no light in any parts it's seemed dead what i cand do to solve this problem?
thanks for answer
best regards
Ugo cecchetto
Posted on Dec 01, 2008
  • 659 Answers
Try pressing Fn+F6 might work but to me sounds like the lcd is shot if you have any external connections to hook it up to a tv or a computer monitor i would try that out and see if anything comes up as well if it does then its the lcd you might have to press Fn+F5 to switch from lcd to monitor or other external device. I think that is what it is for your model.
let me know if its not and I will make sure of it.
Posted on Nov 30, 2008
My acer 5102 wlmi tries to start then goes straight off, the power pack warms up but no power
the cpu fan is probably not working ,and the cpu overheatrs almost in a second and shuts off..try setting it on a laptop cooler and starting it..clean the cpu fan vents..check the fan
Jul 22, 2009 | Acer Aspire 5100 Notebook
When I press power button, only power button is lit green solid and nothing else happens...nothing on the screen...all black. No sound codes. Tried external monitor...nothing. CPU fan keeps running....
yes its motherboard. GPU has failed. Most likely you'll need to get your motherboard Reballed or Reflowed. I have found some reasonable business partners that do this service through ebay. usually runs 80-140 to get fixed. good luck!
Ruben
Jul 18, 2009 | Acer Aspire 5100 Notebook
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
Acer aspire 4520 won't boot
Try this.
Unplug both AC ADAPTER and remove battery.
Press and hold POWER BUTTON for 30 seconds.
Plug in AC ADAPTER.
Turn on.
After log in, place battery in.
Apr 26, 2009 | Acer Aspire 4520-5950 Laptop
Acer aspire 5100 wont start up
i think the computer gone to power save or hibernation mode. get the battery off from laptop then put it back, turn the computer on. it works, if not consult some hardware technician i think it is not a major problem it can be fixed easily. if warrenty is valid, avail it...
Oct 20, 2008 | Acer Aspire 5100-5033 Notebook
Acer 5100 Has no screen
It sounds like the mainboard or CPU died. Generally the hard drive is fairly easy to remove, look on the bottom or the side for a screw labeled "HDD", which should uncover the hard drive area.
Feb 25, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
