Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
How to access Dlink Set up page ?
I have D Link model DWL 2100 AP
http://192.168.0.50 does not opens and http://192.168.1.1
takes me to my ethernet beetle
how can i access my dlink set up page and make my wireless secure?
  • wdsaleh Dec 25, 2008
    hi, i connect my access point dlink dwl-2100 ap to my notebook thru the cable but the page 192.168.0.50 doesn't open , i have window vista business
I can't able to connect the http://192.168.0.50 please give me solution.
Posted on Mar 25, 2009
You must be in the same subnet as your device in order to configure it. If you are in the 192.168.1.0 subnet, change your IP address on your computer to the 192.168.0.0 subnet. Assign yourself a static in that subnet with the last octet between 1 and 254, but not 50. I use 192.168.0.250, but any unused IP address in that subnet will do. Once you are in the same subnet, you should be able to reach your AP. If you still can't get to the http interface, then go to plan B: Your access point came with a CD: D-Link AirPlus Xtreme G AP Manager that provides an alternate client interface. You can setup security and change the password, and SSID using the client interface software if your http connection does not do it for you. Once you change your IP to the 192.168.1.0 subnet (which I assume you intend as it sounds like that is your LAN subnet), give the AP the gateway address of your router's IP address, and change your IP address back to whatever it was on your computer.
Posted on Dec 03, 2008
Hello when i turn on my access point d-link dwl 2100 ap i couldn't access to it by the ip i reset it several times but nothing changes even by the default ip of it 192.168.0.50 so plz help me
In order to get to the web server, you plug an ethernet cable between your computer and the AP. Then, did you miss the instructions that you have to be in the same subnet? Right click on your LAN card (Network) Properties TCP/IP Properties and set the address to something temporary like use 192.168.0.5 or anything but 1 or 50 and the subnet mask to 255.255.255.0
Now when you open up IE, just key in 192.168.0.50 and it will bring up the login box.
Carl
Apr 14, 2011 | Computers & Internet
Is there any limit for wireless D-link DWL-2100 AP ?
D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides speed upto 108Mbps, which is the maximum wireless signal rate derived from IEEE Standard 802.11g specifications. However, the actual speed depends upon the wireless network environment, setup and devices.
For further details please refer to DLink Official Product Description
Nov 26, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Dwnot able to login D-Link dwl-2100 AP
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi If you are still not able to access with above ip then press RESET button for 10 seconds it is in back side of router then all settings defaults then you can access it with above ip . Let me know if you need further assistance. Thanks for using FixYa.
Oct 09, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I am not able to login my new dwl-2100 AP acess point
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
DWL-2100AP
To use the DWL-2100AP as an access point (repeater), You have to set it up on the repeater mode and type in the MAC address of the router. The best way to do this is to run the AP manager from the cd.
Here is a link to the D-Link support page. Click on product manual from under the Support resources
http://www.dlink.com/products/?pid=292:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Enquiry
repeater, as in a link up for wireless node to node communications?
hmmm...www.dlink.com
check your computer's warranty here FREE
Feb 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
1,753 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
