Question about Canon LaserClass 2050 Plain Paper Fax
How do I reprogram the numbers on speed dial ? and or add them or delete them?
I am trying to reprogram the numbers on speed dial but it keeps beeping and won't let me. Also I need to know how to program the numbers on the 1touch speed dial also. I know ingenious but it seems as though no one in our office is able to.. asap please thanks
Canon left me on hold for 30 minutes then told me this wasn't their problem and I should call my dealer for service.  I'll try that now.  Nope - they didn't know either.
Eureka!  Lift the panel that covers the speed dial buttons and push the button labeled "data registration".  Using the arrow buttons find the speed dial info and figure it out from there.  Good luck!
Posted on Oct 23, 2007
  • 193 Answers
Go to CAnon or call their 800 help desk. They may send you a users manual. canon is very nice at helping..to a degree! We fix canon MFC here, but parts are iffy.
Posted on Jan 19, 2007
How do I reprogram the speed dial numbers in my Panasonic KXT61610 phone system?
Try Googling (Panasonic)(KXT-61610)(manual) without parens.
Jan 23, 2018 | Lands Phones
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
How do I program a speed dial out side number on the buttons to the right?
What happens when you dial "9" on the intercom? If that gets you an outside line, then press PROGRAM, one of the buttons, and dial 9 plus your number and STORE.
Hmmm...Speed dial :-)
If you get a vacant line at "9", then you need to reprogram your 400 line access on your phone sytem to disable the vacant lines.
Carl
Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
I can't change the speed dial numbers on my phone
You should only have to hit Feature - Redial and then select the soft key that you wish to re-program. Typically you will then type 1 and then the extension you want to program.
Jul 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Re-programm speed dial keys
Sorry delete it/them and reprogram. Carl
Jun 10, 2009 | Ricoh FAX2900L Plain Paper Laser
Problem with speed dial buttons
to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Feb 23, 2009 | NorStar M7324 Telephone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Speed Dialing
Press PROG press a speed dial button (ie 13-24) dial 9 plus the number press STORE
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Resprogram speed dial numbers problem
You can reprogram them using bitpim.
Jun 10, 2007 | Motorola Mobility RAZR V3
Canon LaserClass 2050 Plain Paper Fax Logo
421 people viewed this question
old marine
old marine
