My computer needs a clean out. - Computers & Internet
  • 340 Answers
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temporary folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Posted on Nov 29, 2008
In general, how do I clean my computer?
Using an air compressor give it the mother of all blow jobs in every nook and cranny. Your computer will be very clean and very happy!
Jan 09, 2016 | HP Computers & Internet
How do i wipe my computer clean
That depends on what you mean by 'clean'?
Also, I'm answering (rewording) your question to: 'How to clean out your filesystem and data on your drive'. Hoping that's what you meant?
If you want to 'wipe' your computer so it is impossible for anyone to ever recover any file, then what you do is physically destroy the internal hard drive, and then purchase a brand new 'clean' one!
If you want to 'clean' out all junk files and start your computer 'clean' again, generally most run the operating system image back through it again (these 'images' are sometimes accessed via a Fn key at startup, but refer to the computer manufacturer for more help)
If you want to just clean out everything from your hard drive and start 'clean'. Then you just need to remove the partition, or even format the drive.
To do this, the drive you want to format cannot be 'in use' at the time. There are many bootable CD's and USB drives that can start your computer so as to 'clean' your hard drive out.
Jun 12, 2014 | Microsoft Computers & Internet
The best way to clean computer
Leave it plugged in to eliminate static discharge, take the covers off and use a small brush and a vacuum to clean out all the dust that is on the heat sinks on the CPU and the power supply. Clean the fans and the motherboard.
Feb 09, 2014 | eMachines Computers & Internet
Sometimes if am working on my computer, it will just hang, turn screen to blue, shut dowm and retart slowly authomatically. how can you help me solve the problem?
Good day,
It seems your computer need cleaning and maintenance maybe too much dirt and need to put new thermal paste.
Solution
- Clean Dirt
- Replace new Thermal paste
- Clean Fans
Tnx
Aug 19, 2011 | Computers & Internet
SAYS I NEED SYSTEM SERVICE
These intrusive software program do this because it is there job to do this and that with your computer. If it says you need service it means that you need service cleaning up your computer or the software needs you to make a selection to continue. Over 26 years of computer I have used just about every software program in the world designed to make your computer run better they claim.
Registry cleaners, hard drive fixers, clean up of unused files etc. Anti spyware and anti mailware and others are designed to do the work for you while working in the background slowing down your computer even more. You can do all of this stuff on your own when you want to do it. Disk Clean and Defrag are given to you for free it comes with Microsoft's Operating System under Accessories and Go to System Tools.
Microsoft Security Essentials handles all the other things necessary for keeping your computer fail safe. All the other things are added sector suckers that do nothing but bog down computer systems although they do their job it is just another program to purchase which are ofter contracted with computer companies to come with your computer at the time of purchase then they want to get into your pocket book.
Just a suggestion delete that software and get the Microsoft Security Essentials then clean and defrag regularly that is all you need. Your computer will run faster I can tell you that much. Just a suggestion? Speaking from loads of computer software testing. John
Jan 21, 2011 | Iolo Technologies System Mechanic: Windows
I have a completely blank screen and a tower revving with 3 bleeps about every 3 seconds. Can you help? De Hayward
This indicates that no RAM/Memory is being detected by the computer.
The RAM modules need to be removed and cleaned of dust. The gold fingers may be cleaned with tissue paper.
Insert them one at a time, in alternating slots. They may need to be cleaned more than once. A pencil eraser will also give a good clean contact surface.
Happy Computing!!!
damnor01
Jan 05, 2011 | Dell Inspiron 530 Desktop Computer
When running video or playing games fan seems to run loud the whole computer shuts off
That means the heat sink processor is clogged and needs to be cleaned. When the computer can't cool down the processor, it detects overheating and shutdowns to protect the processor.
The back of the computer needs to be removed and the heat sink needs to be cleaned. I do not recommend you to do it if you have no previous experience cleaning computers.
Dec 23, 2009 | HP Pavilion dv4000 Notebook
Image or Ghost my pc
what type of computer is it?
Oct 23, 2008 | Acer Aspire 3680 Laptop
D300a shutdown
With the message you are getting on your screen,there are couple things you need to do.First thing you need to do is make sure your cooling fans are all working if they are your next step is to go out and get a can of compressed air to clean the heat sink on the processor and any other cooling fan that needs to be cleaned before doing this unplug your computer to be on the safe side.If the heat sink looks clean you may need to remount the heat sink using thermal paste.Remember after cleaning your computer try to clean it often this is one thing that most computer user's overlook.
Aug 09, 2008 | Insignia D300a PC Desktop
Computers & Internet Logo
Alun Cox
David Payne
David Payne
