Question about GE Profile JB968 Electric Kitchen Range
FO (function error) keeps appearing in GE Model JB968SOK1SS.
This occurred during cooking our turkey for Thanksgiving 2008. We are now trying to use our self cleaning function and it is occuring again. In 6 days, we are having a formal dinner for 18 people and my oven has to work. What can be done to correct this issue!
  • ineedspam Mar 22, 2009
    I have the same stove with the same error, I came on during a self clean cycle. Hav eyou had any luck having your repaired?
  • 213 Answers
SOURCE: Need to clean oven GE true temp self clean
the oven temp sensor is bad. replace temp sensor to solve problem
Posted on Nov 19, 2007
SOURCE: Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Posted on Dec 08, 2007
MNTECH
  • 1543 Answers
SOURCE: GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Posted on Nov 29, 2008
scottowa
  • 87 Answers
SOURCE: My Dacor ER36D wont heat after self-cleaning. What should I do?
I would guess you probably have a element out. These stoves are suppose to be self cleaning but I can't tell you how many times I go to repair a stove and it's usually after self cleaning. I'm not in favor of self cleaning becuase it gets SO hot for SO long it really stresses out everything in the stove. If your element is exposed, look for cracks or any iregularity. If you can't see it, it will be under the bottom pan and that usually comes off with 2 screws in the back. Elements can be found about anywhere. Here is one spot.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Posted on Feb 15, 2009
  • 2976 Answers
SOURCE: Grease caked on the oven from a spill
First--Look for a couple release levers around the bottom of the oven. You should remove the bottom and scrape the spilled grease off. If you can't remove it, clean off what you can before using a standard ovencleaner. It will still need to be washed well before firing it up.
Easy Off Oven Cleaner has been around for years.
Posted on Feb 21, 2009
I have a 30 qt pot, cooking a 18 lb turkey. placed turkey in pot and added water. amount required is above maximum limit level. Can I exceed?
If you are frying it, no you can't. As moisture comes out of the turkey, it will cause the fat to boil over.
You say you 'added water'. You are making boiled turkey for Thanksgiving? You could, but not the same.
I have two suggestions.
Cook traditionally in the oven. I am a chef and have cooked my turkeys breas t side down for a bout 20 years. The result is a much moister breas t on the turkey.
or
Split the turkey and deep fry in two batches.
The word breas t is considered as profanity on Fixya. Please review your answer and try again.
Nov 25, 2015 | Bayou Classic Kitchen Appliances - Others
The label on my frozen turkey says it is good till March of 2016 does this mean even if its thawed it will still be good till that date?
Hi Ronnie:
- If it has been sitting unfrozen in your fridge for more than 2 days I'd personally not be eating it.
- Likewise, if you cook it, it should be eaten right away.
- Re-freezing uncooked is not considered safe food protocol.
- Freezing cooked in serving size portions and only thawing when you're going to heat and eat is usually safe.
Hope this helps.
Nov 14, 2015 | Toys
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
Oven door is locked and won't open
Sorry to hear the "self clean" Gremlins are at it again. Several things have happened, none good. During the cycle at full power for several hours, a circuit on the control board has failed. Various errors are now keeping functions from occurring normally, although sometimes door switches fail causing similar anomalies. At any rate 'self clean' eventually becomes 'self-destruct'. Boards run 150-300$ . Hope info helps- Thanks-ED
Feb 27, 2010 | Kitchen Ranges
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
I am looking at buying the new hidden heat element
It sure can. Whirlpool has some wonderful appliances and their ovens have a very large capacity for your Thanksgiving turkey or what ever you cook. The best of luck to you and enjoy your huge new 30" oven.
Sep 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Burners light ok, oven will not light
Stop time knob needs to be out; you set it for timed bake. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Nov 25, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Alternative cleaning for a self cleaning gas oven
easyoff makes a oven clean that is for selfcleaning ovens. just make sure you get the one that says for self cleaning oven and youll be fine
Nov 24, 2007 | GE DBSR453EBWW Electric Dryer
GE Profile JB968 Electric Kitchen Range Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
