Question about JVC KT-SR2000 SIRIUS Radio Receiver with Car Kit
Antenna not detected / Searching for signal
I currently flop my JVC KT-SR2000 between two vehicles. I recently began seeing this on the display when i run it in only one of the two vehicklies. I am thinking that it is the mount or adapter. I have a relatively new antenna and the unit is getting power and overriding the set FM station. I am kind of in a bind, sirius does not offer this unit any longer, and I have been unable to find replacement parts for the car kit. Aside from antenna that is, but its universal.
  • 4 more comments
  • Anonymous Dec 06, 2007
    I have same problem, problem has gotten worse over time. I switch radio multiple times per day from boom box to car cradle to home cradle. Problem is the worst in the boom box. I believe problem is poor connection on the round antenna connector, it's as if one of the parts is not quite long enough. I've tried opening the radio to see if the plate with the contacts could be adjusted, but I couldn't even get the radio open, and I was afraid of breaking it.
  • Anonymous Feb 16, 2008
    I have the same problem. I found out it is the connection to the antenna that needs to be repaired and it looks like it can't be fixed.
  • Anonymous Jul 01, 2008
    Even though I am using a Stiletto 100, I have the same problem, but only on the home base, not in the car. I replaced the home base, and it worked for a while, but now here it is again! I am convinced that it's a weak connection in the multi-connector on the home base. I'm going to try spraying it with an electronic cleaning spray.
  • rodgerskenne Jan 12, 2009
    my sr 2000 started displaying the "acquiring signal" message about a week ago. At first it just happened upon turning on the unit, and would go away within minutes, Eventually this time got longer & longer, and finally the display just stayed on - radio signal was never, and still is not acquired.
  • Anonymous Feb 28, 2009
    I am on my FOURTH radio receiver in the past five years...and this one is also becoming useless as it is frequently displaying "Antenna Not Detected". Once this one goes (should be soon), I will be canceling my subscription (although I really love it).
    Problem Solver:
  • 4 Answers
I just had the same thing happen the radio is 4 yrs old and has never been removed from the car. I called sirus and they sent me a test signal that seemed to work on and off for a few days. I finally when to crappy tire and got a new one. Considering the programming is 200 dollars the 39.99 antenna was worth it
Posted on Feb 13, 2010
I had the same problem with antennas lasting only about a year mounted on the roof. You can get a better price on e-bay but won't solve the problem. I ended up using my boom box antenna on the dash. It works quite well but signal is intermittent on tree covered roadways. Other than that, it works great.
Posted on Jul 18, 2008
I have the same problem. It's happened twice now. Each antenna has lasted about 1 year. The connection is good, the antennas just stop working. It's almost like there's some built in life span. Who knows. It's ridiculous either way.
Antenna Not Detected. Now I have to buy a new one AGAIN $39.00 and re-wire thole whole thing in my car. PITA
Posted on Jul 14, 2008
SOURCE:
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
Display does not work
HI. I lost my code for radio ford focus serial number M227636
Feb 03, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Disassembly of JVC KT-SR3000
Did you get it open? remove the two screws. Those are all the screws on the outside. Gently pry the halves apart at the bottom of the unit. Gently try a flat screwdriver. GENTLY! Theres some tabs that hold the rest together. You may break one or two but will be ok in the end. Do the prying at the bottom so you dont break the tabs at the top.
Apr 09, 2009 | JVC KT-SR2000 SIRIUS Radio Receiver
KT-SR3000
Had this problem with mine. turned out to be bad solder joints. Take the unit apart and solder these joints and it should fix the display problem.e0ae4d7.jpg
Jul 31, 2008 | JVC KT-SR2000 SIRIUS Radio Receiver
LCD screen back light doesn't work
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality.
Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
Feb 20, 2007 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Reception and audio intermittent
Sorry I can't help. I'm having the same problem. Seems to be a common problem with these units. I posted the same problem. If you get an answer before me could you please forward it to me and I will do the same for you. THANKS AND GOOD LUCK
Aug 06, 2006 | JVC KT-SR2000 SIRIUS Radio Receiver with...
JVC KT-SR2000 SIRIUS Radio Receiver with Car Kit Logo
1,210 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
