Question about HP LaserJet 5p Printer
Have to keep setting up HPLJ 5P on a USB port everytime I print!
I have a HP LJ 5P that I have connected to my laptop via a USB to parellel converter cable. I installed the printer and added the drivers both form the XP CD as well as HP website but the issue persists.
When I install the printer, I have to select a USB port. It works fine as long as the laptop is not rebooted or the USB cable not disconnected. Once either of theses happens I have to remove the printer and readd it on a different port to get any more prints.
If anyone has any insights I would appreciate the help. Thanks
  • tmurtaza Nov 29, 2008
    Appreciate the fast response LLINCON. I have tried this and the issue still persists. Any other insights would be appreciated. Regards
    Sergeant:
  • 217 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Nov 29, 2008
I bought a Laseret 6L and a usb adaptor cord to replace the parellel port connection on the computer end. I've tried every suggestion regarding ports, but nothing works. The test page prints OK, but...
I've heard there is special software needed to do the USB to parallel conversion. We have a customer using a LJ 1000 with this hook up and there is supposed to be a driver/conversion software that handles the issue. Here is a good discussion that may have some solutions for you.
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1268956879623+28353475&threadId=1087380
Mar 18, 2010 | HP LaserJet 6L Printer
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
Hp laserjet 5p will not print with new computer (Vista)
check cable for error take a other printer to try
mostaly if you connect usb in the usb port then it select the poort 1 or 2 or 3 and find the printer if you chanche it for a other poort it wil not see the printer
Sep 27, 2009 | HP LaserJet 5p Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
HP 3015 AIO printer Won't print
Yes, you are correct in that you have to select the USB port from the driver in order for the printer to print to USB, or install another driver for the USB port.
Nov 22, 2008 | HP LaserJet 3015 All-In-One Printer
Why is my printer showing a idle status and not printing?
I believe the printer is connected via USB.
Check in device manager if the LJ 1020 printer is listed.
If yes, go to the driver properties > ports tab and Select the appropriate port for the printer
Alternatively, uninstall the full software and reinstall it again from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439320&
- Nikhil
Nov 18, 2008 | HP LaserJet 1020 Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 5p Printer Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
