Question about GE JVM2050 Microwave Oven
GE Mircowave JES2251SJ -
After operating for about 10 minutes the unit stops heating. It gets very hot. After cooling off it will operate normal for another 10 minutes.
Is there a cooling fan and where is it located?
  • GE Master
  • 9,098 Answers
The internal magnetron cooling fan is located behind the control panel assembly.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Dec 02, 2008
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
I have a model #401-80089700. The inside wall next to the controls will get hot and the microwave will shut off. after it cools, the display comes back on and it will work until it get hot again. It
all units have a thermal fuse that stops operation when case over heats . try replacing the thermal fuse could be out of tolerance.. looking for an obstruction in the high voltage radiation ducting that could be obstructing the flow of high voltage radiation , or the defuser belt or motor is no good or slipping, also the cooling fan obstructed or failed. .. all above to be handled by a master or journey man teck. or tv repairman. A professional not an novice.
Jan 21, 2015 | In Microwave Ovens
GE over range microwave JVM1870SK03 stops working approximately 3-4 minutes into heating cycle
<--- I'm happy to help you. Yes, it's overheating and the magnetron's thermostat is opening to protect the magnetron until it cools, then it turns power back on.
It could be due to a failed or unpowered cooling fan motor. Have your cooktop lights gone out recently?
When a cooktop bulb goes out, a surge may occur if the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
I repair boards in such cases.
It may instead be a dirty filter.
If the unit is set to recirculate, it will use a charcoal filter, which should be replaced every 6-12 months.
If it's not set to recirculate, then the grease filter may just need to be washed.
Or your ductwork may be blocked by an animal nest or debris. The entire duct and the outside vent / flap must be clear.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 20, 2013 | GE JVM1870 Microwave Oven
The Microwave shut off after a few seconds. I removed it from the wall and took the cover off. I fired it up and initially it behaved the same. I checked wire connectors that were readily available. Did...
It will get hot in a very short period of time. Could you have set the time for a few seconds instead of a few minutes? Thermal issues normally take the unit out until replaced. They are one shot thermal protect devices.
Sep 06, 2013 | GE SpaceMaker Microwave Ovens
Sunbeam chest freezer SBCF5WBX appears to operate but suddenly stopped being cold. It defrosted and thawed contents. Power is on and all electric lines and connections are in good condition. Freezer is...
Where you say that it appears to operator, do you mean that the compressor is working? If so, then your condenser grills might be dirty and causing the unit not to cool effectively. Is the sides or back of the unit getting hot? If so that could be the cause - a cleaning of the condenser coils.
But if your compressor is not kicking on or is very hot to the touch, then it might not be operating correctly. If it is not activating then it could be the contactor-relay or start capacitor.
Sep 10, 2011 | Microwave Ovens
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
Jan 01, 2011 | Samsung Microwave Ovens
The microwave will heat for 2 minutes and then shuts down, no power and nothing works. After 5 minutes it will click back on and I have to reset the clock and wait till I decide to use it again. If I use...
Hi there!
This may be temperature related. The microwave is fitted with thermal switches which opens when it gets too hot. this bypassing all current running to the point of operation. Normally there is a switch mounted on the magnetron( the item which heats the food). If this runs too hot it will cause the switch to open. If left off for a while it will reset under normal temperature. This I think is your problem. However it will have to be seen to by a repairer. Hope this helps you in your decision. Best Wishes and Good Luck. JUS004
Aug 24, 2009 | GE Microwave Ovens
Timed Power Loss
It sounds like your magnetron is failing, but generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 28, 2008 | Whirlpool MH1150XMQ Microwave Oven
GE JVM2050 Microwave Oven Logo
136 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
