I have a intel d845gebv2l motherboard that has a 3 pin connector on the MB that is connected to the PS. Do you knpw what this is used for?
  • 105 Answers
As I can't see on schematics, where, and how many pins are.
Here is the full user manual. D845GEBV2
I think you will locate them more easier than me.
Plz have a nice vote as it is needed for me to be hired.
thx
Posted on Nov 29, 2008
Audio jumper setting
You should have a 6 pin jumper.Pins 1 and 3, 2 and 4 for Normal. OR 3 and 5 , 4 and 6 to invert
Mar 15, 2012 | Intel D845GEBV2/ D845GEBV2L MB, Retail Box...
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    ASUS M3N-HD - CASE (w/ PS): Foxconn- TSAA-725 . The problem is that the case has a Power led connector which doesn't fit with the module on the board. It like CASE: 10, MB: 1-0. "-" stays for a space...
    So, the M/B has a 3 pin connector, but your case only has a 2 pin connector? Easiest way is just to cut the connector from the case in half with a pair of sissors.. It isn't the most nice solution, but it works quite well!
    Jun 02, 2009 | Zerus Intel Desktop Board D815EEA...
    Connecting front panel wiring to INTEL 845GRG Motherboard
    Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
    See page 9 for motherboard layout.
    The front panel connectors are shown on page 68, see item C.
    On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
    Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
    Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
    The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
    If this manual is not what you see on the MB, please advise.
    Good luck davideiker1!
    Need more information/questions post here.
    Thank you for using FixYa.
    Input, comments are welcomed.
    Mike
    Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
    T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
    According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
    If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
    Steven
    Sep 17, 2008 | E-Machines (308714) Motherboard
    Need specs on ax6b mb
    CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
    ASIC: Intel 440BX AGP set
    Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
    Max. Memory: 1 GB SDRAM for DIMMx 4
    DIMM Type: 8/16/32/64/128/256 MB
    BIOS: AWARD plug-n-play flash ROM BIOS
    On Board I/O:
    2 serial ports (UART 16C550 supported)
    1 parallel port (SPP/EPP/ECP supported).
    2 floppy drive supported (1.2/1.44./2.88 MB)
    2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
    2 USB ports supported (universal serial bus)
    1 PS/2 Mouse Port
    1 PS/2 Keyboard Port
    On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
    SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
    Battery: 3V lithium battery
    Green Function: Yes
    Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
    Board Size: 244 mm x 305 mm, ATX form factor
    Apr 13, 2008 | Computers & Internet
    Mother Board connection
    Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
    The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
    http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
    Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
    Good luck & please vote....
    Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
    Computers & Internet Logo
    410 people viewed this question
    Alun Cox
    David Payne
    David Payne
