Question about Bosch Axxis+ WFR 2460 Front Load Washer
Washing machine won't spin or rotate
I have a bosch wfr 2860 washing machine with an intermittent fault where it will run through the entire cycle but not rotate or spin the drum.
This only appears to occur if I've pressed pause at any point in the wash. Filter is clear.
The resolution is to take the back off the machine and wiggle the brush connector on the motor. Any ideas what the problem is?
  • Bosch Master
  • 3,463 Answers
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
Posted on Nov 30, 2008
Bosch washer goes through cycle but tub does not rotate
this sound like the brushes in the motor
or it might be a fault on the pump
Dec 30, 2012 | Bosch Axxis+ WFR 2460 Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
No Spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Not spinning
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
448 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
