Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pool burners will not come on thermacouplar is working.
Is it in the hot cold control or is it in the thermastat, does this work like a hot water heater?
  • 1,420 Answers
Jump out the thermostat to test the unit. If it comes on, you have your answer. If it does not come on, you will need to look at the control.
Posted on Dec 05, 2008
I have a mini max 150 pool and spa heater i have replace the pilot assembly and the theremal couple and the ignitor i have a great flame on the pilot but when i turn the valve to on the burners wont lite...
if pilot stays on and heater wont fire......problem with one of your safety switches, or problem with thermostat controls, or a bad connection someone within the entire circuit
Sep 30, 2013 | Pool & Spa
1992 subaru legacy 2.2 liter overheating and no heat. already replaced waterpump,thermastat, radiator and hoses
You mean the car is running fine but just No Heat?
If so
-Sound like the heater hoses are plug. or the control valve is no function
-Check the heater control valve and flush the heater unit with water of garden hose from both directions.
Q: How do I know that is working or not?
A: Slide the heater control from Hot to cold or cold to hot and check it turn or not. (If not turn at all. The cable is broken or slip off)
Mai Lor
Feb 22, 2013 | Cars & Trucks
Burner stays on, no control
check temp sensor if not reading that its hot enough it will keep running if ok see if not calling for heat if not gas valve sticking open replace
May 21, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Problem..went to reinstall thermastat..was no thermastat in car. the housing was cracked, broken and is leaking antifreeze..why did the air work if no thermastat was in it???
Thermostat holds water in motor until it heats up to thermostats temp. While thermostat is closed (holding water back) it allows water in radiator to cool. When thermostat opens cool water enters engine through lower hose, hot water into radiator. When cool water hits thermostat it closes again and repeats the cycle. Your A/C is not dependant on heated water as when air is on, heater valve in heater hose is closed. Get yourself a new housing, gasket & thermostat and fix it right. An added bonus is you'll probably get better gas mileage with correct thermostat.
Jan 02, 2011 | Pontiac Grand Am Cars & Trucks
Water heater heats water, but not long enough or sometimes not hot enough. The hot water runs out too fast, does not provide hot water continually
The first thing I would do is turn up temp control on gas valve.Control is located on front of gas valve at the bottom front of heater.They usually have a indicator dial on front with an arrow pointing direction.Turn dial to higher setting when burner is not on and this should turn burner on and provide hotter water. The control is normally turned clockwise to increase temperature.If control is already turned all the way up then water heater may need to be replaced.Depending on water quality in your area heater may have a large amount of mineral build up and it may not be capable of producing enough or hot enough water. If this the case all I can suggest is to try to drain tank and flush some of the deposits out. If you have installation manual it will give you instructions on how to do this. If not see if you have working shut off valve on cold water line ,if it works shut it off and connect drain hose to drain valve on bottom right side of gas valve. Put hose to floor drain or sump basin if you have one. Turn control knob on top of gas valve from on to pilot,this will leave pilot light on but prevent burner from working while draining. Open drain valve ,flow rate may be slow or not at all. Open hot water side of some faucet to provide air to help draining. You may try opening water supply valve to heater a few times to aid in draining. If you can get it to drain,shut drain valve off when done,turn cold water supply back on and shut off hot water outlet. Then when tank is full open hot water vavle to bleed air out of heater and piping. Turn control knob on top of gas valve back to on position. This should bring burner back on .It will take about 1/2 hour to heat. If you can't get it to drain or this doesn't help you might consider getting a new 40 gallon heater. Hope this helps. Thanks
Nov 11, 2010 | Reliance Water Heater #6-30-YORT 30GAL NAT...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
Heating is not working. We have change the
Lower intake manifold could be gone or heater core plugged.
Dec 05, 2009 | 2001 Ford Taurus
Heating & Cooling Logo
111 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
