Question about Samsung SyncMaster 753 DFX 17" CRT Monitor
Samsung monitor problem
I bought samsung monitor on e-bay guy said was working I get floating message checksignal cable my computer is fine its a dell
3 Suggested Answers
rubydu
  • 102 Answers
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
it shwos a compability issue with ur pc and monitor .somehow your sync signals are drop and not going to monitor at proper level...so u could replace your video data cable with new one.
or use a short length cable.it may solve your problem.
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: tried installing samsung syncmaster monitor and
If anothe monitor works fine plugged into the same slot, check the cord that goes from monitor to PC, on the monitor side, make sure it is seated firmly.
Posted on Oct 10, 2009
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
Jan 29, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor colors suddenly changed
If you can't adjust the color settings, using the control panel (buttons) of the monitor, it's physical/internal faulty. In most cases this can't be repaired. But I would suggest you to try (repair), if there's only a short circuit or loose connection, it'll be easily fixed.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | Dell E176FP 17" LCD Monitor
Tried installing samsung syncmaster monitor and get and error message check signal cable dialgoue and can't do anything, previous monitor works fine
Does the new monitor work correctly when installed to some other computer (notebook or desktop) ? If it, you have a "dud" that should be replaced, under warranty.
Try changing the data-cable between the monitor and your computer.
Oct 10, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
I bought a new computer and my existing Samsung 24 inch flat screen monitor doesn't work with it. I see 6 buttons on the front of my monitor but I don't know how they work. Unfortunately, if a manual came...
If you have the (white connectors) DVI cable correctly plugged into the computer, when you turn the computer on, it should recognize it and make the needed changes automatically. Maybe not if the PC was already on even though it's plug&play.
If you have the model number of the monitor, you can google for the manual.
Jul 25, 2008 | Computers & Internet
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Jan 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Oct 14, 2007 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 753 DFX 17" CRT Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
