Question about Vivitar ViviCam 3746 Digital Camera
I have a question. Can I use a 2GB memory card in my camera?
Instructional manual only list up to 256 MB.
Will a GB memory card fit in camera and work?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Any SD card up to 2GB in size should work in this camera.
Posted on Aug 09, 2012
  • kakima Aug 09, 2012
SOURCE: MEMORY CARD
had since my memory card said he was full, but in fact had just format on the computer, then tried a bit and find the solution like this: put the memory card, press the menu button shows where the photos stored , Delete> Format, then everything returned to normal.
Posted on Aug 20, 2008
SOURCE: Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Posted on Aug 25, 2008
manoline
  • 52 Answers
SOURCE: sd memory card for vivitar 3935
Yes, you can use a 2gb SD card with this. You can use any memory card brand, just make sure it's an SD card.
Posted on Nov 08, 2008
  • 10 Answers
SOURCE: i have a vivitar vivicam 5022. will a lexar 256
It most likely will but it will not store a lot of pictures due to the pixel count of this camera
Posted on Dec 07, 2009
lock123
  • 6831 Answers
SOURCE: New camera, new 2gb memory card saying memory card
Hello
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
If it is a new camera , you should take it in for a exchange.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Hi, I recently purchased a contax tvs digital camera, functions well except it wont accept the 2gb sd card or a 16gb.
If this camera is what I think it is (Model No.1000300), I believe the max amount memory card that you can put in this camera is 500MB. That's MB (megabytes), not GB (gigabytes). That camera is a fairly old 5.0MP (megapixel) model, probably from the mid 2000s. So, no way your GB cards will work. I looked up specs for this camera but couldn't find a max card recommendation, only that the camera supposedly came with a 16MB card. So, try a 1GB card if you have it. If it works, try a 2GB. And so on. Or the other way - if the 1GB doesn't work, try a 500MB. If that doesn't work, try a 256 MB. and so on. You'll finally figure out the max card that you can use. Good luck.
Jan 28, 2018 | Contax Cameras
I have a Sony digital camera model # DSC S75. I would like the largest memory stick available for still photos. I get confused with GM and MB. I found one for 32 GB, is that the lrgest and about how much...
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
Feb 10, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
It's memory card 256 mb. I want at least 1 gb.How can I do it?
The E50 uses standard SD cards, which go up to 2GB. You should be able to buy SD cards at any department, electronics, or office-supply store. Many drugstores and supermarkets also carry SD cards.
Dec 08, 2010 | Konica Minolta DiMAGE E50 Digital Camera
How big a memory card can you put in a DMC-FZ20 camera? I just got an 8 GB card and get "Memory Card Error" all the time.The old 256 MB card works fine.
An 8GB card is not SD, but SDHC (High Capacity). SDHC cards fit the same slot as SD cards, but they are slightly different and many cameras do not work with them.
I have a DMC-FZ20 myself, and use a 1GB card. That is really plenty of space. If you want more (going on holiday?) then just carry a couple of spares. The manual doesn't mention memory cards larger than 1GB. Probably there weren't any when it was written.
Dec 05, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Memory card error
try formating.
but u may lose the data
also see that u format through sd utility available on sd.com
if still a issue than get free replacement by kingston as it has 5 yrs warranty
Jun 21, 2008 | Kingston flash memory card - 256 MB -...
Upgrade olympus d-560 256 mb memory to 2 gb memory
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. Due to the age of the camera Olympus has no plans to provide any upgrade for allowing a larger memory card.
Jun 18, 2008 | Olympus Cameras
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Vivitar ViviCam 3746 Digital Camera Logo
120 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
