Question about Samsung Televison & Video
Samsung HLT5076S - The Standby/Temp light is blinkng green and the TV won't come on
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
Muzzi_123
  • 749 Answers
SOURCE: I try to power on
you need to test the lamp with a ohm meter, to see if its working correctly
Posted on May 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: Standby/temp light and Lamp light are flashing
Sounds like a samsung but I will need the model number to assist you more accurately. Please respond to this same post.
Posted on Dec 04, 2009
  • 3 Answers
SOURCE: I have a Samsung TV # HLP6163WX/XAA. A loud
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Posted on Jan 19, 2010
SOURCE: We replaced the lamp on our Samsung 50
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Posted on Aug 31, 2010
    Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
    tv seems to turn on but no picture? - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
    Jun 11, 2015
    Samsung Plasma TV - Won't turn on
    Jun 11, 2015
    The timer, lamp, and standby/temp. light are flashing?!
    Jun 11, 2015
    Samsung TV Keeps Shutting Down
    Jun 11, 2015
    More results from www.cnet.com
    TV with Black Blank Screen Repair How to Troubleshoot ...
    ? 3:16
    https://www.youtube.com/watch?v=kFdVi2ejfzA
    May 8, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
    Samsung plasma tv repair blinking light no picture ...
    Jan 09, 2016 | Samsung Televison & Video
    Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
    Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
    Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
    Apr 09, 2012 | Televison & Video
    I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
    It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
    Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
    Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
    Hello, I try to help. But your questions not spesific.
    Below are conditions lamp indicators that appear blinking and solutions:
    1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
    2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
    3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
    I hope that solve your problem.
    Thanks.
    Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
    Tv wont turn on Red standby/temp light and green lamp light are both blinking
    The tv projection lamp been inside the tv like 1 1/2 or 2 years already,used tv every day like 4 or 5 hours a daily?The Lamp life are ended.Time to replaced the tv projection Lamp.
    Dec 20, 2010 | Samsung HL50A650 50 in. TV
    Red standby lights is always on and when I try to turn on tv the green temp light blinks once, goes off and then green lamp lights up. TV does not turn on.
    Samsungs problem child, if the lamp is ok, then the best thing is to have a good tv shop inspect it, last three we had where not repairable, needed DMD, Digital board, cost more than tv was worth.
    Oct 30, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
    Sound but no picture - won't stay on
    you may check your lamp first. other than that i would say a faulty mains board.
    Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    No picture and no sound
    Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
    http://electro-medical.blogspot.com/
    http://homenol.blogspot.com/
    If blinks continue without any pause, the main board is faulty.
    Mar 11, 2017 | Samsung Televison & Video
    Televison & Video Logo
    165 people viewed this question
    Henry  Thomas
    Henry Thomas
