Question about Uniden TCX805 Cordless Expansion Handset
Uniden TCX 805 phone book
I have never entered a name or number in the phonebook. Yet, when I try, it tells me that the memory is full. I delete All (even tho there's nothing there) and it still tells me the memory is full. Help! I'd like to use this feature.
  • oregonferrie Jan 19, 2009
    "memory full" prevents adding accessing or deleting phone numbers on Uniden TRU 8880-2
I had to delete the caller id which was full. everything works now.
Posted on May 09, 2008
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
On my model 8885 uniden phone, when I try to store a # the screen say's memory full. I only have two numbers stored. help
These phones use a "Shared" memory, the CID information and the Phone book information share the same memory chip. If you clean out the caller ID data you should be able to load more numbers in the phone book. Since you have an 8885 I am assuming you have TCX800 or TCX905 handset(s), to clear the CID memory, Follow these steps:
Deleting Information from the Caller ID List
1) When the phone is in standby mode, view the Caller ID
information to be deleted (see "Viewing the Caller ID
List" on page 50).
2) Press the DELETE soft key. De let e C all er ID appears.
3) Press volume up/down to choose Yes.
4) Press the OK soft key. You will hear a confirmation tone.
To delete all the CID information follow these steps:
Deleting all Caller ID names/numbers
1) When the phone is in standby mode, press cid.
Press the DELETE soft key. De let e A ll? appears.
2) Press volume up/down to choose Y es.
3) Press the OK soft key. You will hear a confirmation tone
Mar 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
Does the Dect 6.0 recognize when a phone number needs a 1 before the area code (1-800-.......)?   I entered some numbers with the required 1, and some without it.  All the calls went through.   In a few...
If you save from caller ID to the phone book from an out of area code number, the manual doesn't tell you that you have press the * key while the number is displayed and it will insert a 1 before the area code. Do this before trying to call from caller ID or copying the number to the phone book. I had to delete the area code stored in the global set up to get the caller the "*" feature to work for my local calls other wise it would just put a 1 in before the 7 digit number and would not work when it is store.
Jan 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Samsung pixon m8800 fault
my inbox messages get full, i have saved some into my folders but even with an 8G memory card i still have to delete messages. What do I do to get stuff onto the memory card??
Dec 27, 2008 | Cell Phones
Uniden Power Max 5.8
try to give ur phone a soft reset.
to perform that try menu/settings
or any soft reset button in the phone bottom or back
best regrads
if not help tell me.
plz do rate this poste
Sep 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Cant access phonebook
your on the right track 1# then scroll through to find the number without the name and either delete it or add a name to it
Nov 07, 2006 | Motorola Mobility V300
Uniden TCX805 Cordless Expansion Handset Logo
239 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
