Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Greetings!
My mother-in-law went to use her 18-month old Fisher&Paykel DD603i (with integrated cabinet drawer fronts) bottom drawer on Thanksgiving, but it started beeping and showed an error with the motor. She usually just uses the top drawer, since there are only two people in the house. From what I can determine from looking around the FixYa site, this system uses a magnetic system to turn the impeller? Is that correct?
From the messages I've read, it looks like someone here may have a service manual for this unit? If so, would you be kind enough to forward it to me also?
My mom-in-law would greatly appreciate it, and I could probably get an extra slice of leftover pumpkin pie!!
Thanks,
Craig
teamhickson@yahoo.com
  • rozemerry Dec 11, 2008
    my dishwasher is filled with water and when I tried a rinse cycle hoping it would drain the water, I got an F2 error message. Do not want to call an applicance man AGAIN on this dishwasher.
    thanks
    rose
  • Zeusest Jan 21, 2009
    Wow! I can't remember how much I paid for this THING but I certainly didn’t get what I paid for. I've had this washer for about 2 1/4 years and had it break twice. It now is showing Error F2! What the H is F2! And why did I buy a Fisher & Paykel even though it is rated always in the medium range of customer approval? Maybe I'm the one that needs to go into the repair shop. HELL-P!!!!
    Zeusest
    PS: So, how do you get this THING to empty the water form the basin? It's going to get rancid and stink.... THX!
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Posted on Feb 11, 2009
  • 2 more comments
  • mddog26 Feb 28, 2011
    F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
    http://www.appliancerepairlesson.com/sho...
    Good luck
  • Home-body May 22, 2011
    I really like the F&P dishdrawer dishwasher - but the F2 problem had me stumped. Thanks ++ for this - it worked immediately and well!
  • mary lynda Jul 31, 2012
    did this work for you Craig, we have the same problem cannot get the impeller to turn at
  • Hillary Fitzsimon
    Hillary Fitzsimon Jan 06, 2016
    Thanks from us too jscrim... bought a F & P dish drawer second hand. The people said they hadn't used it in about 4 years. Immediately after installing we got the F2 error. Used your solution above and its working like a charm. 2 loads done already! Saved me getting out a repairman...
  • 77 Answers
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
Posted on Feb 28, 2011
Thanks jscrim! I just had the F2 problem with my Fisher&Paykel and fixed it as you suggested which is to unscrew the knob under the rotor arm. You made my day!
Posted on Jan 11, 2010
Top drawer hs no power the lower drawer works fine
Posted on Sep 11, 2011
Posted on Jan 06, 2016
Hey jscrim!, your suggestion is valuable, it worked for me to. My wife is very happy, what else you want. Thanks for sharing your solution.
Posted on Oct 14, 2013
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
How to get bottom drawer out of fisher paykel dd6031
I wasn't able to find an exact match to your reported model (DD603I?), but all of the DD60xx models appear to have the same drawer removal process:
2_23_2012_6_18_56_am.jpgI actually took this from the installation guide for the KitchenAid dishdrawer (also made by F&P), since it had the clearest images.
Dec 24, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Both drawers Fisher Paykel DD603i start Beeping/Draining
the unit as had a lieak your it thinks it as first un plug the unit then try taking out the bottom draw (pull it all the way out then at the bottom front on both sides there is to clips push both clips in and pull the draw it wiil leaft of it runners push the runs back in out of the way then the can see under the in the base of the unit if the can see water or damp dathch plz call an enginner as ther is 5 things it can be
if not water you will see a grey plactic cover in the bottom back right the main pcb is in there witch has a water sencer on it if you fell up to 4remover the pcb and wiep the two prongs that are on the end of it as wiep there it was siting then put back as it was ps the dont need to take any wires to repalces the draw pull the to runners back out sit the draw on them then clothes the draw but re open it and give the to cilps a lite pull to make sure they are locked back in to places pulg it back in and try it if this dont work plz call an enginner as there is 3 pcbs in this unti that will need cheking
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
14,471 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Gere knutson
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
