Question about Maytag Performa PAV2200
Washer maytag lat 9824 dam model washer it will not spin all other function is ok lid switches ok pump ok
  • 116 Answers
TAKE A LOOK AT YOUR LID SWITCH MAKE SURE PLASTIC PLUNGER IS MAKING CONTACT,, SHOULD MAKE CLICKING NOISE WHEN OPEN AND CLOSE LID
Posted on Nov 30, 2008
Kenmore 70 series washing machine won't start draining after washing, the water just sits.
Sounds like you probably have a broken lid switch, without an exact model number its hard to be sure. If you normally have to close the lid for the washer to drain and spin that is probably the part that is broken. Pretty common for that model. With the lid switch broken the washer acts like the lid is open and won't begin the drain/spin process. Hope this helps.
Apr 29, 2018 | Kenmore Washing Machines
WON'T PUMP DOWN OR GO INTO RINSE AND SPIN CYCLE
what about your lid switch?...have you checked it already?
tnx 4 using fixya,
drcool
Sep 27, 2008 | Maytag Neptune FAV6800A Top Load Washer
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
Quietseries 300 : Fills OK, timer functions OK, no water movement
Check the Lid switch. Most top load machines will not spin unless the lid is down and this is determined by the lid switch.
Jan 07, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
My atlantis do not spin and drain .
Check if the motor is running, then proceed as follows:
  1. If the motor is running, the washer has a frozen pump pulley or a broken pump belt. Remove the pump from the washer and try to rotate the pulley manually. If it does not turn freely, it is frozen or stiff, replace it. If the pump belt is broken or worn out , replace it. Check the pump pulley before you change the belt.
  2. If the motor isn't running, the lid switch is probably defective. If it is so, the washing machine cannot spin and may not function at all. The lid switch is inside the washing machine main housing near the door frame. Usually you have to raise or open the top or front of the washing machine depending on the model to get to the switch. If defective, you must replace it. Check it's continuity when activated using an ohmmeter. A defective switch does not have continuity when activated.
Nov 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Older wash mach # LAT 9457AAE shut down in middle of cycle-water in tub. is there a reset buttom on back-or what advice. thanks. john
There could be more than one solution to your problem, if your washer is washing and then at the spin or drain cycle just stops, this could be the lid switch. if this is faulty it won't allow the spin cycle to occur for safety reasons. part number is 22001967 and comes with the switch and actuator as well. you should be able to hear the switch activating every time you open and close your lid. The next possible problem could be that one of your belts has broken, and now isn't turning the drive pulley. part number for the kit (drive & pump belt) is12112425. if these are seemingly okay. i would have it diagnosed by a technician.
Thanks
Oct 14, 2009 | Maytag Washing Machines
Will not spin
If the motor is not running, it could be a faulty timer. If the motor runs, it could be the transmission. Check to make sure the pump belt is ok and the pump pulley is not seized by tilting the machine back and checking.
Jan 31, 2009 | Maytag LAT3600A Top Load Washer
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
118 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
