The mic volume on my volume control is at the highest setting, but the sound is still very low. I can't do voice chat on google voice because it's very low and cuts out.
SOURCE: Microphone does not pick up voice
I am sorry to say but I think that perhaps your Microphone is faulty? These headset leads are notorious for breaking. If you know how to use a meter, perhaps you could check the circuit, and "see" if there is a Microphone attached? Could you "Test" it on another PC? But if this isn't the case below are some helpful links.. I "Googled" this --->troubleshooting microphone problems xp? http://support.plato.com/kb/tip.asp?psid=26055 www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/speech_setup_microphone.mspx
SOURCE: Headset Doesn't Work...
Same problem for me, except the headphones wont work with team speak or playing back voice from the sound recorder, I just get a low frequency quiet and very muffled and distoreted sound, Mic works fine with speakers though. :(
SOURCE: don't have speech recognition tab in control panel-speech
Go to control panel click on sounds audio dvices then tab on voice and click on test hardware then click on next now there are two options one is recorder and second is playback. Now click again on next when you click on next both volume should be enable then click on next and then finish. Now 100% guaranteed it will work and you can voice chat now. Cheers!
SOURCE: USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
