Question about iLO 3200 32 in. LCD Television
Ion 32 inch tv
Will not power up
  • economy Nov 29, 2008
    the tv has has always been hard to power up and after several attempts it has powered up
  • iLO Master
  • 19,396 Answers
At a glance this looks like a problem ith the power board, try first leaving the set unplugged for few hours and see if it restarts.
If the TV led stays on, and TV does not start but you can see that there is power getting to the TV, then the TV is in protection mode because it has detected an internal fault , and you will need to call a technician.
If instead the TV does not start at all and there is no power at all getting to the unit:
If you leave in UK check the fuse inside the AC plug, you do not need to take apart the TV to do this.
If the Cord/Plug is not fused, there is a fuse inside the TV , on the power board, but to replace this you also need to take apart the TV, and therefore is advisable to call a technician.
Posted on Nov 29, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your description of will not power up, does it refer to completely dead, no lights or any indicators at all? If yes, then it is a power supply issue.
If you are considering a DIY (do-it-yourself), common known issues are:
diode(s) in the bridge and indicated by a blown fuse;
additionally, some of the components are not sufficiently heatsinked;
if you would prefer board replacement rather than component level repair, the ILO's PSU (power supply unit/board) would look like the image below and is available from here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 29, 2008
    This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
    Referring back to the insufficiently heatsinked component, another common/known issues with some versions are heat related causing cold solder on some of the joints. Corrective action would simply be re-soldering and a bit of soldering lead.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 146 Answers
Capacitor Is fucked...
The job of the capacitor is to charge up to the amount of voltage the runs on your T.V and it seems its not doing that I would take it back if warranty is still good get repaired or get a replacement.
  • Patrick Shaffer
    Patrick Shaffer Nov 29, 2008
    Don't try opening it because if it is the capacitor it has alot of voltage about 25k Volts and that is more than enough to kill you.
    Genius:
  • 1,550 Answers
Check the inlet power socket to the tv is proper .
Check for any fuse being blown.
  • iLO Master
  • 13,433 Answers
Check the powersupply for a blown fuse.
The picture on my 32 inch curtis flat screen tv does not work. what do I do?
I think i may need a new power cord for my 32 inch curtis. where would i be able to get a replacement?
May 18, 2014 | Curtis LCD3227A 32-inch LCD TV
Need a power mother board for a emerson 32 inch tv model number lc320em2
does anyone have the part # for the power inverter transformer for the LC320EM2 A the board #BA1AFGF0102 2. The transformer I am looking for is the largest yellow transformer, thnks.
Sep 03, 2012 | Emerson 32-inch 720p LED TV Refurbished
I have an HD 32 inch television and the power wont
Talk to Sylvania about your TV. If your TV is fried (if it's off it's still vulnerable) they MIGHT be nice and replace it. I recommend you protect all your electronics with surge protectors, since they'll help you should this happen again.
Jul 13, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
The 32 inch TV started to have promblems turning on at first... then you had to unplug the unit to get it to turnn on, now you cant turn it on at all. Donthe 32 inch TV started to have promblems turning on...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 03, 2010 | Akai LCT3285TA 32 in. LCD Television
32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
May 27, 2008 | RCA 32F531T 32" TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Apr 13, 2007 | Sharp 32C241 TV
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
