  • Anonymous Mar 26, 2014
    Foggy tv screen
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Posted on Apr 21, 2009
My Polaroid TV is connected to Virgin yet most channels are pixelated and the tv looks like it needs fine tuning, but i can't. Any help?
on the tv screen menu go to display and reset the a settings the larger the numbers the better the picture --apply and ok
Oct 22, 2017 | Polaroid 4241-TLXB 42 in. LCD Television
My 40in polaroid flat screen tv cuts off 5 seconds after i cut it on,what can i do
thats usually a power issue maybe bad caps. You can get power supplies and free tech assistance from
Mar 16, 2012 | Polaroid Televison & Video
Do I need to ever clean the bulbs and mirror?
Only if your picture looks hazy or foggy and not clear.
If you do not know what you are doing or haven't done it before call your local tv repair shop.
Jan 20, 2010 | RCA HD52W59 HDTV Projection Television
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
My car a 1999 jetta failed inspection for a foggy headlamp
try to pollish out the scratches, thats what the hazy look is , road dust at highway speeds turns into a sander and scratches the clear lens.there are kits made just for this or I normally use meguires number 7 fine cut cleaner and a buffer with a cotton pad.
Mar 27, 2009 | 1999 Volkswagen Jetta
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
HD stations have no picture, sound only. Other inputs show picture.
or antenna try ch 5 ch 12 re auto scan the chs in menu again readjust antenna
Jan 29, 2008 | Toshiba 46H84 46" Rear Projection...
Samsung digital cam vp-d351
First try to take photo in a sunlight, if the photo is still hazy then clean the lense and make sure you dont put your finter anywhere in front of the camera.
If the photo is still hazy then it could in internal camera fault.
If the photo is fine in the sun but its blurry in the dark then take photo with flash if thats ok then you just need more lighting.
Also make sure the ISO Rating is auto or 100 many people set ISO to 800 and then forget about it. It causes hazy photos in the dark
Nov 02, 2007 | Fuji FinePix F401 Digital Camera
Cant tune my Hitachi TV
please check web site for any thing in remote. and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
