Question about Whirlpool Washing Machines
Knocking while spinning
Duet HT front loaded washer
GHW9250ML1
Type 199 080 SC/WG
1. A loud knocking occurs while the basin is in spin. The basin wobbles while spinning. When the basin slows it knocks louder. What is the problem and the solution?
2. The estimated time of 1 minute can last for upwards of 20 minutes, cycling in and out of spin/drain/tumble/spin/drain/tumble and so on...
  • 121 Answers
Something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Posted on Nov 29, 2008
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
THE DRUM WHEN SPINNING MAKE LOUD KNOCKING NOISE? THERE ALSO IS LONG MELTED PLASTIC PIECES COMING FROM FRONT DOOR AREA.
the plastic pieces are from the friction of the metal spinning onto the white plastic, Part cost about 187 but I am thinking of just ditching this crappy washing machine, something is always going wrong. call me 3616432681
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very loud knocking during spin cycle
I just had a technician tell me that problem was caused because the main rotor bearing was bad. Apparently, it is a sealed bearing that comes apart due to the excessive spinning. The repair charge is $800.
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
309 people viewed this question
Dan Webster
Dan Webster
Sal De
