Question about Kenmore Dryers
Dryer heating element cycles on and off every minute or two
Kenmore dryer heating element cycles on and off every minute or so and does not dry the clothes and i do not want to replace all of the thermostats and fuses as i think only one is the problem
  • 5,911 Answers
It is normal for the dryer heating circuits to cycle on and off. The heating element is not supposed to stay on continuously. What usually causes excessive dry times, and rapid cycling of the heating element is poor ventilation. The following link explains:
Pay particular attention to the paragraph that discusses proper ventilation and how to determine whether or not you have a clog. You could STILL have a malfunctioning hi-limit thermostat or operating thermostat, but I suggest you double the simple things first. It doesn't make since to replace parts if it may be a simple matter of general upkeep. Cleaning the lint trap in not enough to keep the dryer ducting clean. If you've never had your ducting inspected or cleaned, now may be a good time.
Perform the simple test of disconnecting the dryer vent hose and try drying a load. If the dryer performs better, you may have a clog in the vent line where it leaves the dryer to where it exits your home. If the drying results are still the same, inspect the internal air blower to make sure it is not clogged.
NOTE: It is also recommended that you use semi-rigid metal ducting. It is crush resistant, resists kinking & heat, and offers protection against rodent infestation.
I hope this advice leads you in the right direction. Let me know what you discover. If it is not a matter of ventilation, then read the steps on how to determine the whether or not the heating circuits are operating correctly. Let me know if you require additional assistance.
Posted on Nov 29, 2008
Model 110.62982101 dryer kenmore elite electric
sounds like maybe bad heating element first check out ur thermostats hi-lo, thermal shut off, and cycling thermostat with a multimeter. also check element for continuity
Sep 15, 2014 | Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Dryer will not dry - hte heating element has just
check the hi-limit and cycling switches on the element case and the thermal fuse on the vent ductwork
Mar 12, 2010 | Dryers
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Heating element
Internal ductwork
Cycling thermostat
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 28, 2009 | Kenmore 64902 Electric Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Dryer shuts off minute or two into drying cycle
not sure with out model # but if there is a rmovable lower panel and dryer has even heat control bd suspect control also look for a thermistor this is a black thermastat looking part with 2 small wires mounted to blower housing beside a white thermal fuse
May 21, 2008 | Kenmore Dryers
Dryers Logo
508 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
