Question about Whirlpool Dryers
My whirpool dryer does not dry. Drum works fine. No hot air
  • Barry Coates
    Barry Coates May 11, 2010
    Could be one of several things.
    Can I have mod no please?
  • 5,911 Answers
The following link will give you some helpful advice on a dryer no heat problem:
Pay particular attention to the paragraph that discusses proper ventilation. Clogged, or poor, ventilation is the number one cause of dryer heating circuit failures. Inspect the ventilation and internal blower fan housing BEFORE replacing any defective components. Failure to do so may result in premature failure of the same components.
I hope you find this information helpful. If you require additional assistance, please let me know.
Posted on Nov 29, 2008
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Jan 19, 2011 | Whirlpool Dryers
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to
Feb 26, 2010 | Whirlpool Dryers
Drying on-and-off
I would replace the coils on the burner valve assy.
Mar 17, 2009 | Whirlpool Dryers
Kenmore Model 110.747424000
check your exaust blower wheel...its defective
Dec 12, 2008 | Kenmore 72802 Gas Dryer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
