Kenmore 11020802990 Top Load Washer won't spin!
  • Anonymous Mar 04, 2009
    My washer will fill with water and agitate, but won't spin or drain. When the main on/off knob advances to the "spin/drain" portion of the cycle, there is a humming noise coming from the area of the knob for about 30 second and then it goes away. The cycle basically stops there and won't proceed any further. I turned to knob to other cycles to see if the drain/spin would work and get the same humming problem followed by stopping.
  • 116 Answers
IS THERE WATE INSIDE MACHINE ,,IF SO REPL, LID SWTICH ????????
Posted on Nov 30, 2008
  • Johnny Ramirez
    Johnny Ramirez Nov 30, 2008
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Kenmore 80 Model #11020802990 Won't Spin!!
i think you have a basket drive tube problem, what happened to mine was the thrust washer had ground off the bottom of my tube,the clip that holds the brake release arm fell off,the arm fell down breaking the 2 little pins on it, without that arm on the tube it won't release the brake allowing the basket to spin, you would have to remove the tranny to see if there is a problem there,,,,,also the top of the tube there is 2 notches that line up in your drive block,could be broken there,,,,you would have to remove the agitator to check there!
Feb 20, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore model # 11020802990 stoped spinning a
Check the motor coupling. Remove the cabinet, pump and motor and see if the coupling (designed to break if the transmission or motor jams) is broken. Check the Sears site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
for part number :
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor Number:3364003Substitution:285753A $18.50 In stock Quantity Add To Cart
Manufacturer authorized substitution: 285753A may differ in appearance, but is a functional equivalent to prior parts including 3364003. If it isn't the coupler, it most likely is the motor.
Sep 14, 2009 | Kenmore 24902 Top Load Washer
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
When my washer spins, it sounds like somehting is loose. kenmore 80series , model#11020802990 type111
does it continue to spin and make noise when you open the lid?
could be the drive block.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
