Question about HP PSC 2210 All-In-One InkJet Printer
Error I have hp2210 all-in-one for a while and I love this. It started to say "Error-right cartridge incorrect" I believe this is quite a new ink and I tried to put it back,turn it off,cleaning.. Is there anything I can do to fix this? Please let me hear your suggestions. Thanks
Try cleaning the contacts on the printer with a QTip and some rubbing alcohol. If that doesn't work, you may just need a new cartridge itself. What can happen is the contacts on the cartridge will "expire", and the printer can't read it.
Posted on Sep 06, 2007
SOURCE:
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
Cartridge error HP2210
Buy a new one. It is the correct cartridge, but it might be "broken". That happens all the time- one of the wires on the cartridge electronic has blown and the printer now does not see the cartridge, that's why you are receiving that message.
Feb 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP2210 all in one. I got the error:
remove the catridge and clean it with tisue paper and install it again if the problem is continue then replace the catridge.
Jan 22, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hp2210 all in one. i put a new ink carthridge in. it keeps telling to alighn carthridges. i press enter & the printer alighns the carthridge # prints the report. the printer keeps telling me to alighn...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error right cartridge incorrect
I Change The New Ink cartridge Align ink cartridges paper can not print
Sep 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Right cartridge incorrect and printer will not
I have the same issue where the printer displays "Right cartridge Incorrect". However, it's had no problems up until about two weeks ago and I've had the right cartridge in place for about a year or so.
Printer: AIO 922 (All-In-One 922)
Ink: Remanufactured ink
Jul 11, 2009 | Dell 924 All-in-One InkJet Printer
Refillied black ink cart. causes error.
The ink cartridge is bad get a new one after a few times of refilling the ink cartridge they go bad. Hope this helps ya
Cheers
Johnthetr870
May 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check print cartridge
Remove the cartridges and check them. If faulty, replace them.
Sep 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Right cartrige incorrect
This error means that the printer is unable to read or load the cartridge.
Try to rub the golden parts on the cartridge with a smooth damp cloth.
And in the contacts where the cartridge has to be placed also clean it.
Now install the cartridge & check.
Are you using the compatible cartridge with the printer, this message will came if the installed cartridge is not compatible with the printer.
Check with the known good that is the cartridges which you know that worked with the printer to make sure that there is nothing wrong with the printer.
If the error message comes call the manufacturer to checkand replace the cartridge.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
117 people viewed this question
Clive
Clive
Thomas F. Schneider
