Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
92 Cadillac deville
I need to remove the heating core. But I don't know how. I'm removing it because I have no heat in the car and I need to install a new one.
#1 is great advise! Also, be SURE that you note how all wiring and connections come off. I had this done by a mechanic and had to take it back three times before they got the connections correct (I think I could have done it better myself).
Posted on Oct 26, 2009
  • 24 Answers
Go to the auto parts store or amazon or the library. Find a Chilton's Manual for the Year and make of your car. In that book you will find step by step instructions on how to remove and reinstall your heater core
Posted on Dec 18, 2008
How to change heat core on 1995 Cadillac Deville
If it is like my 1999, you must remove the entire dash--not for the faint of heart!
Jun 09, 2015 | 1995 Cadillac DeVille
How to replace heat core 97 cadillac deville
You will need a repair manual for your Cadillac. On some cars, the core is accesible without removing the heater case from car. On cars where you have to remove the case to replace core, it can get to a real pain point. There are some cars that require the whole dash to be removed first, before the heater case and core can be gotten to. Hope for the best-and get the manual. Libraries also have good reference/repair sources.
Nov 05, 2011 | Cars & Trucks
My cadillac is not giving me any hot air ,ive replaced the radiator, changed the thermostat, has a new water pump, where do istart to look.
Feel the 2 tubes at the firewall for the heater core. If they are not getting hot, the heater core needs to be flushed out or replaced. I had this problem with a 1990 Cadilac Deville, it was just a plugged up heater core.
Remember to install sealant after flushing out the system to prevent leaks.
Jan 25, 2011 | 1992 Cadillac DeVille
I have a 1998 Cadillac deville its over heating and theres water in the passenger floor board
Sounds like heater core is leaking,you can check under the hood where the heater hoses go into the firewall and make sure they are tight but you will likely need a new heater core...ope this helps
Nov 27, 2010 | 1998 Cadillac DeVille
No heat fog's up inside
Do you want to know if it is the heater core. If you perform a pressure test on the cooling system it will pin point the source. But I does sound like the core.
Jun 01, 2009 | 1991 Cadillac DeVille
I have a 1991 cadillac deville
I have a 92 Deville. All the flushing in the world will not fix the cloged up heater core. The flush will clean out the passenger side of the core but will not clean the core on the drivers side. I have just repaced my core and seen how these fail, It is a bad design that caddys are known for. It was recomended I do a total flush of the system every 30,000 and then just maybe I would not have to endure the core change again. As the antifreeze runs through the car it does a chemical change due to all the different metals and rubber it flows through. since the heater core is small with small bands to let the coolant in and out, it builds up with the sludge from the chemical change. Thus closing off the drivers side first. Note, both the inlet and outlet are on the passenger side, you really cant flush fluid where it builds up the sludge in the core. Solution, new core after trying a flush
Dec 18, 2008 | 1992 Cadillac DeVille
Heat not blowing 92 cadillac deville
check you fan, or door controls under dash,
leroy
Dec 13, 2008 | 1992 Cadillac DeVille
1991 cadillac deville NO HEAT
I had the same problem in my 1991 caddy, and turned out to be the blend door. It is located in back of the glove compartment. There are two kinds, the automatic blend doors and the manuel ones. Since the temperature is automatic and programmed to stay where it is set, it would be an "automatic blend door". Not a hard fix...
Oct 18, 2008 | 1991 Cadillac DeVille
63 cadillac sedan deville heater core removal and installation instructions
I do think you have to pull he dash, for that you will need a manusl, try ebay for used factory manuals, I have had good luck getting them there for all my cars.
Oct 17, 2008 | Cadillac DeVille Cars & Trucks
Heating & Cooling Logo
57 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
