Question about Mitsubishi VS-45607 45" Rear Projection Television
Power turns off after a couple seconds
I have a Mitsubishi rear projection TV 45" and when I turn it on there is a click sound then a whining sound then it shuts off. There is no sound and no pic. It was working great and I have never had a prob. with it before this. it is about 8 years old. I checked the boards and did not see any burn marks or any other signs of anything wrong. It has 3 fuses and the one furthest from the power suply surges. the power to it goes on and off really fast about twice a second. The fuse is by a horizonal circuit board to the rear right of the tv.
Did you ever get this tv fixed? It sounds like the Power board needs to be replaced. I have a similar problem and I was wondering if you got your tv fixed?
Posted on Jun 20, 2007
  • Lynn Haag Jun 21, 2007
    I figured it out! For me there are two sets of very small cables about 2 inches long which are connecting the PCB-Power Board and the PCB-Main board under the center of the color guns. These are like ide cables. They get knocked loose and start to come off due to the faulty design of the connector. Unplug the tv first, then simply open the back of the case look for the breaks in the boards you should see clearly 3 main boards, one near the inputs(PCB-Signal), one in the middle (PCB-Main), and one one the right side looking from the back (PCB-Power). In between the PCB-Power and PCB-Main you will see these little ide cables and connectors make sure that they are firmly pressed down. For me that was it! case solved! I hope that you were as fortunate! PS let me know if this helps you!
I do not have an answer butthis is happening to me now and read where it happened to another Mitsu.TV owner. they should be made to fix it because this looks like an equal to an auto recall.
Posted on Jun 11, 2007
SOURCE:
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
TV does not turn on. Turn it on and there is a
Replace Both of your STK ICs they are big black ics will have part number on them STK392-110s example ,Call Mats for Parts 1-800-628-1118
Nov 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Unit turns off after 3 seconds
sir i think theres something wrong with the power supply kindly check it out thanks and hope too help you,,,gud luck
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-4507ca
It just click ON and OFF, right? If you hear the hight voltage noise tring start, may be the Tv has bad vartical IC or regulator IC. If you have no experience with electronic you will need a technician to halp you.
Sep 11, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
