Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer stops after filling
My washer stops after filling..wont advance to the wash cycle unless I go do a "fonzie" on it and smack the top of the control panel.
  • 121 Answers
The lid switch is bad or the hinge that hits the switch may be loose
Posted on Nov 29, 2008
GE washer wont stop filling with water
If your timer dial doesn't advance and it just keeps filling sounds like a bad timer.
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Washer is stuck on wash cycle,,wont fill wth water and wont go to any other cycle.
Can you manually force it to go to other cycles? If so then the timer or control board is the issue. If you can't even make it advance then the control board is most likely. Check your pump and make sure it is not clogged and therre fore njot allowing the waqter to drain out =as it ias supposed to. If the water is not pumpiong out the washer will not advance
May 11, 2011 | GE WJRR4170E Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washing machine wont hold water on any setting
    raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
    Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    My Kenmore Washer 110.92281100 won't stop
    I purchased a new timer, installed and solved the issue.
    May 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washer wont stop filling
    There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
    Apr 27, 2009 | Kenmore 46462 Front Load Washer
    Won,t drain on rinse cycle
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Washer stopped
    Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
    I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
    Dec 04, 2007 | GE WBSE3120B Top Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    110 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
