When The car is on the front parking lights are always on. When I use the turn signal (right or left) I can't see the front signals flashing but I can see the power fluxuate in the battery meter. Only when I use the turn signals. I have a 1600 watt amp in the car and at peak power the battery gauge doesn't budge so I don't think it's a weak battery or alternator. Anyone have any ideas on what it could be or how I might be able to track it down?
SOURCE: my turn signal lights wont work on my 95 firebird formula
Go under the dash on the drivers side, and locate the two flasher stat units. These are small round aluminum 'cans'. They plug in, and have flat blades on the bottom. (You of course won't see these flat terminal blades until you unplug them)
One is for the turn signals. One is for the four way flashers. I can't tell you which one is which.
Past this point, check all the grounds for the turn signals. The wiring harness at the front will have one, or two leads, (Wires), coming out that bolt directly to metal. Either sheet metal for the car, or to the frame. These leads have flat, round terminal ends on them, with a hole in the middle of the terminal.
The lead's terminal end bolts can work loose causing a bad ground, and/or, there could be corrosion in-between the terminal end, and the area of metal it bolts to. If so, use sandpaper, and clean the terminal end, plus the area of metal it bolts to.
There are ground leads, (Or lead), that come out of the rear wiring harness also. Check these.
Still no?
Then your turn signal bulb sockets have corrosion in them. This causes a bad ground.
You may be able to use a rolled up piece of sandpaper, and clean the socket.
(Also touch up the lead, {LED. As in the metal lead}, contact point in the middle of the socket. This is for the Positive connection, but it doesn't hurt to clean it while you're there.
After this is the turn signal switch in the steering column.
(My money is on a bad flasher unit)
SOURCE: i have a 2002 pontiac aztek. My rear right
as for the faster flashing thats as simple as a blown bulb, replace the bulb and see if that fixes the problem, it may fix the lot because the other symptoms you mention are a bad connection, if bulb is fine check the connection isnt loose or corroded over. if it is simply file it back to establish better connectivity,
SOURCE: I have a 2001 Pontiac
Perhaps a dicky connection somewhere. Perhaps corrosion, even moisture in the connection plugs. Inspect all connections to your indicator lights. Also check for worn or damaged wires. Also Have a look inside the lenses of the lights to see if the the globes are corroded or have water ingress etc and causing shorts to other wiring within the lighting circuits.
You may also consider turn indicator lever to on to indicate truniong right, make sure the engine off. Have someone watch right indicator and literally grab the plugs/leads to the indicator globe and give them a shake to see if the fault goes away. If it doe stop intermitantly then it will help point you in the correct area.
SOURCE: Need to replace left turn signal flasher
This is weird! It seems to me that the left turn signal is getting 12v from somewhere at all times.I don't think the flasher is the problem(most GM systems use a single flasher for left and right)You probably have a crossed wire somewhere(or an add on accessory was connected to the left signal wire,allowing 12 volts to bleed through to the circuit)
