Question about Toshiba Satellite A55-S306 Notebook
Overheating when plugged in to mains
My laptop overheats/screen flickers when plugged into main power source. It is ok when just using battery, but I have to power off to recharge it.
4 months ago the screen/backlight died. This has been replaced. The transformer was also replaced.
  • 41 Answers
Their is a clear sign that the converter has gone corrupted ,,,,it is a hardware issue
Posted on Jul 22, 2009
My g60 -235dx laptop on startup error message say communication problem with I/O deveice, HD, flash drave , CD-ROM
G60-235dx. (2011 model, is my guess)
ok tell the full story please.
PC boots sequentially.
progress in that matters. so it seem windows unstated runs?
XP?
so you power on and what happens ?,
errors before windows logs in or after.?
my guess #1 is the main laptop battery is bad, remove it.
this pC runs on AC power pack endlessly, (AC power good)
dim screens. can be bad CCFL lamps or low power in the PC.
so again take out the battery
what flash drive, remove that, test the pC with no usb devices at all plugged in.
just an A.C power pack and no main big battery.
this PC has old CCFL lamp tubes that all go dim, fast.
turn yellow then dim the flicker and then DIE for ever.
all do. some in 2 years time never turned off. they do.
it the screen goes black use a flashlight if data is good on the screen the back lamp is croaking. (***** of CCFL tubes)
there are many cause of black screens, I can list 30. (will not)
but dim screens are only
1; main battery bad and shorted.
2: AC power pack near dead. (weak happens)
3: shorts in the main board, modules.overloading power buses.
4: CCFL dim as every one this old does, all do.
see flash light test.
http://www.pcdied.com/monitors.html#flashlighttest
Oct 18, 2017 | HP G60-235DX Notebook
Got a dell latitude d520 charges battery ok will not power up with mains plugged in only works on battery power any ideas
Hi there!
Your laptop is working with just the battery but not with the main power. This issue you have here is usually caused by a motherboard problem but have you tried to remove the battery then try to turn on computer? If it works then you might just need a BIOS update for the computer of not then there's a high chance that the motherboard your using is having a problem using the main source.
Hope this helps!
Sep 07, 2011 | Dell Latitude D520 Battery PC Notebook
My laptop sony vaio will not hold a charge for very long.
battery backup problem replace a battery or purchase a new battery.
Sep 02, 2011 | Computers & Internet
I bought A sony VAIO VGN-TXN29N when i plug the system battary its blinking and its not charging please advise what can i do regards
The likely cause of this problem is a common mistake in the way laptops are used.
A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life.
This means that it should be used in a similar way to a cellphone's battery - connected to mains electricity and charged up when low or flat and then disconnected from the power and used on battery power alone until the power level means the cycle needs repeating. Many people, however, unwittingly use their laptops like desktop pcs and leave the mains electricity connected to it even after the battery is fully charged. The reason that people cite for doing this is convenience.
However, laptops have more flexibility than cellphones in that, if they are mainly used in one place rather than as mobile devices, then it is possible to charge the battery to full, disconnect from the mains, then remove and keep the battery until the next time the laptop's mobile function is required (periodically recharge the battery if not in use for long periods of time because the charge slowly dissipates when not in use), reconnect the mains to the battery-less laptop and use it like that, ad infinitum.
When a laptop battery is fully charged, what it really wants to do is discharge but maintaining the mains connection, prevents it from doing so. The power management system on the motherboard is designed to cope with long periods of either battery powered or battery-less mains powered use, but not long periods of simultaneous battery + mains powered use. The battery has no means of discharging and various power sensitive components such as the inverter, backlights, lcd panel and graphics chips can become damaged by the power bottleneck created.
Using the battery in this wrong way also gradually depletes the charging capacity of the cells, until eventually, the cells can carry no charge, meaning a dead battery. A dead battery, where the cells are depleted, left in the laptop with the mains connected, is even worse for the power management system because the flow of power to the motherboard via the dead battery cells battery is inefficient and intermittent, creating battery overheating, low fan speed, inferior cooling, internal overheating hazards to the potential electrical damage to several components.
Loose DC jacks, leading to intermittent power drops and surges, are typically caused by the jack being allowed to take the weight of the heavy transformer box on the laptop's power cable. The solution is to ensure that the laptop is never held, carried or used with the transformer hanging unsupported. If the laptop is in use, the transformer should be disconnected, carried, placed on a desk or table near the laptop (if the cord is short) or lain completely full-weight-flat on the floor (if the cord is long enough).
Also, always use a surge protector for computer equipment, never directly to the mains.
If the battery cells are dead, you require a replacement battery.
If either the Motherboard Power Management System or DC Jack are damaged, your laptop requires professional specialist repair by a Component Level Laptop Repair Specialist, providing No Fix No Fee, Warrantied Repairs ( typically 3-6 months Repair Warranty).
When you get your laptop back after the repair, manage the power in the way described above and you should hopefully avoid similar problems in future.
Also check for any damage to the cable where it joins to the transformer box. Also, obviously check for blown plug fuses.
Hope this helps
Aug 02, 2011 | Computers & Internet
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP pavillion ZD8000 laptop will not operate on mains power. To recharge the battery the machine has to be upside down. There would appear to be a loose connection wher teh mains adapter plugs in to teh...
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 10, 2009 | Computers & Internet
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
My Ibm T22 wont boot up
Try removing the battery and unplugging the computer. Then put the battery back in and plug the computer in and turn it on.
Jan 08, 2009 | IBM ThinkPad R51 Notebook
Treo will not complete call
Try with a new battery, also the connection cable between the battery and the main board uses to loose contact, try unplugging and plugging again the cable which connects the battery with the main board. A symptom that the battery is loosing power is that the screen flickers while making a call.
Aug 30, 2007 | Palm Treo 600 Handheld
Toshiba Satellite A55-S306 Notebook Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
