Question about Panasonic DMR-E85H DVD Recorder
Having a iproblem with my DVD Vide Recorder DMR-E85H
Your comments explain a power problem and change Cap C120 & C1261, my power supply looks differant and has not got these cap. my power unit is npx507e4-3
5 Suggested Answers
SOURCE: Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Posted on Dec 06, 2007
Palmbeach
  • 185 Answers
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
Posted on Feb 24, 2008
SOURCE: PANASONIC DMR E85H dont startup
I was playing dvd and it just stopped and message came on saying ( please wait) It still has dvd in and cannot get it to do anything
Posted on Mar 08, 2008
SOURCE: Panasonic DMR E85H Shuts down when playing DVD or dubbing
the ic chip fixed mine tried to contact panasonic to give them negative feed back .its imposable
Posted on Mar 28, 2008
Check the power supply capacitors.  They tend to leak and go faulty.  If so, replace them.
Posted on Sep 09, 2008
DMR-E95H doing self check for up to an hour
Your problem may be Panasonic's common capacitor failures. Open case and look for capacitors with bowed out top and yellow substance. Replace both with higher rated capacitors from Radio Shack. Will need some soldering skills. Look on this site for "solder c1260 c1261"
Sep 01, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd video recorder dmr-e85h is dead
I had same problem. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
Good luck.
Also for those interested, I found the "commands" listed on http://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h to correct problems.
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
No lights or power indication at all on my DMR-85HP.
I had same problem - No Power/No Display. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
If replacing the capacitors doesn't work, try replacing PSU Regulator - STRG6353.
Good luck.
Jul 02, 2009 | Panasonic DMR-E85H DVD Recorder
DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
May 30, 2009 | Panasonic DMR-E85H DVD Recorder
High pitched noise regardless of power on/off
Hello... I would say that your power supply is going bad. But it does sound like the little muffin fan in the unit is.
May 10, 2009 | Panasonic DMR-E85H DVD Recorder
DMR-E85H Remote is malfunctioning
i can supply you with one if you are intrested?
Dec 02, 2008 | Panasonic DMR-E85H DVD Recorder
DMR-ES10 DVD... dead Problem
That's the one who's broken by me. I replaced this cap. and the one right next to it (c1261?), 16V/1500µF
It's working again!!
Jul 19, 2008 | Panasonic DMR-ES10 DVD Recorder
Nov 25, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
374 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
