Question about Blueant Supertooth Light Bluetooth Speaker Car Kit
Need to find out how to set up caller id on supertooth 3
  • 827 Answers
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Posted on Dec 24, 2008
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do you pair an iPhone with the blueAnt st3?
Step 1: Activate Pairing Mode on the Supertooth 3
Make sure the Supertooth 3 is turned off.
You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down.
With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue.
The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken.
The Supertooth 3 is now in pairing mode.
Step 2: Apple iPhone
Now you need to use your iPhone to search for Bluetooth devices:
Select Settings.
Select General.
Select Bluetooth.
Wait for your phone to search for devices, then select your BlueAnt device from the list.
If you are prompted for a PIN, enter 0000 (four zeros).
Select Connect.
Your BlueAnt device is now paired.
Jul 12, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
Jun 14, 2011 | Apple iPhone (16 GB) Smartphone
I need to solve my caller id problem on my nokia 5800 xpressmusic
Hi, if you are activate caller ID or deactivate it,use this instruction below:
Go to phone Menu,
Enter phone settings,
Scroll to call,
Scroll to send my caller ID,
Click and you will see 3 options,
1.set by network(default).
2.yes
3.no.
You can click the desired options from the 3 options.
Hope it helped.
Take care.
Jun 28, 2010 | Cell Phones
AT&T 974 Caller ID has quit.
Unplug everything then replug should reset the Caller ID
Dec 11, 2009 | AT&T ATT-974 Corded Phone
Need to know how to set up the caller ID feature
After your caller id is enabled by carrier, you will get it automatically if your processor is release 3 or higher.
May 21, 2009 | Lucent PARTNER18 Corded Phone
Caller ID date and time doesn't show up on cordless phones
Here is a link to the manual for the 756 series of Uniden phones.
http://www.uniden.com/pdf/DCT756om.pdf
You should just have to set the caller ID time and date. Hope this helps.
Mar 29, 2009 | Uniden DCT756-3 Phone
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
111 people viewed this question
Top Blueant Radio Communications Experts
aliasger yq
Paul Chapman
Paul Chapman
Greg P
Greg P
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
