My lg front load waser the detergent and fabric softner drawer is stuck
    Problem Solver:
  • 3 Answers
I do not know if this will help but on some machines when you pull the tray out a bit there is a little plastic bit somewhere that is like a child safty clip that you press and it should release the tray
it could be under or inside the top
Hope it works Sue
Posted on Nov 29, 2008
How do I get the stuck detergent drawer open?
U see the blue colour softner drawr inside the detergent drawr just push it down after u remove ur drawr it will come easilly
Feb 25, 2015 | LG Tromm Front Load Washer And Dryer Set
Water overflows from the detergent drawer
Check this tip out...
I know it is about the fabric softner, but I think that the problem with the detergent is inthere also...something is dirty and plugged up...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 23, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Where do i out the laundry detergent, when there are two sections
Look closer at drawer that comes out. The labels for pre-wash and wash are under the lip on my LG. Stand to the side and look towards your hand that opened the detergent drawer.
May 12, 2009 | LG WM2487H Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking detergent and fabric softner
Possible your inlet into the tub from the detergent drawer is clogged; try pulling the drawer out gently to clean out. Or use a tooth brush. If you are good at 'do it yourself ' jobs you could open up the top of the machine to see what the problem is. If the machine is under warranty, call the dealer.
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
