Question about Microsoft Xbox 360 Console
XBox 360 game you can hear it but you can't see the game
You can hear the game but you can't see it, it shows a black screen
  • 12 more comments
  • Rooster16 Nov 29, 2008
    No video output, audio only... console light is ok....
  • Anonymous Dec 12, 2008
    we can hear it but cant see it.this 360 is junk we have had nothing but trouble with this thing
  • Anonymous Dec 28, 2008
    can hear but cant see
  • pulvinojoe Dec 29, 2008
    I am having a very simiilar problem. My 360 is 3 years old, and over the last few months I was getting some discoloration of the screen during game play. Usually a green tint that would go away after 15 minutes or so. Then yestyerday when I turned the 360 on I hear the sound but the screen is black. I tried replacement cables today, but it did not work. I also tried the reset reccomendation below, but that did not work either. I am not sure what to do next? Any suggestions???
  • adisx06x Jan 06, 2009
    when i turn on my xbox i can hear the sound but i cannot see anything and the cables are all set correctly...what should i do....
  • Anonymous Feb 17, 2009
    i use hd but when i do i can hear but cant see it...and when i switch it to tv mode the colors are all messed up wut should i do?
  • Anonymous Mar 07, 2009
    when i turn it on little white dashes come on the screen then it stops and all i can do is hear it
  • sasukemist Apr 03, 2009
    well i really dont have the same problem, my screen becomes black and i cant hear anything -_-. So i disconnect everything and about 2hours later it works again! But when i come back from school the next day, the same thing happens. Any advice??
  • Anonymous Apr 06, 2009
    same thing happened to me
  • longhorns554 Apr 11, 2009
    xbox has alot of problems they need to fix them before they start selling them
  • WoLvEzJoN Apr 14, 2009
    i turn on my xbox 360 and i have little white dots and i can hear the game as normal but im not gettin a screen i have tryed it on many tvs and the same problem what shall i do ?
  • gussy619wwe Apr 26, 2009
    rite i think it is "audio and no video" and i have bought a new scart lead i turned it to tv and put to the right channel and the screen was just blue and i could hear the audio but couldnt see anything
    please help i cant bear being without my 360
  • Anonymous May 02, 2009
    i can hear but i cant see
  • jen-meister Sep 15, 2009
    yeah i am the same, my xbox will be on and the sound works and everything, everything is connected, yet i STILL cant see the picture...help?
Ok boys now this might work for some of you out there with the "no vedio problem" but it might not if your 360 is actually broken. i talked with microsoft and we worked together to find a small fix. it does not work 100% of the time but there still is a small chance.
Start off making sure the AV adaptor is set to "TV" or "HD" depending on what type of tv you have. then turn on you 360 with your first player controller when the 360 console turns on hold BOTH the left and right triggers and hold them down. then once you see on the console that first player is plugged in hold "Y" this should reset you 360 settings and restart you xbox 360. were not done yet unplug the power cord from the console along with the AV cables, wait 15-20 seconds then plug them back in and turn on the 360 from the consle if this does not fix the "no video problem" then you might want to look online for 360 repair guids, or sell it to gamestop and they will give you $40 store credit for a broken 360, or do what everyone else does send it in to microsoft. good luck boys.
Posted on Nov 29, 2008
Well, i've also expirenced this problem with my xbox 360 so first turn on your system then put a dvd in then when you hear the sound running keep it on for 10 or more minutes then press the open button on your 360 and the screen should appear if it dosen't turn the system on and off it worked for me i hope this helps good luck!
Posted on Jun 22, 2009
Ive had this problem to what you need to do is wrap your xbox console with towels to where it cant get any air turn it on and wait until it overheats then let it cool down and turn it on and it should work
Posted on Dec 17, 2009
I TRIED THIS FIX AND IT WORKED!!!!! THANK YOU SOOOOOOO MUCH!!!! HOPEFULLY IT WILL WORK FOR A LONG TIME!!
Posted on Dec 29, 2008
Yo every body if u have this problem take the step of overheating ur xbox on solution numer 4 he is a ******* jeanious thank you so much u save my life
Posted on Jan 16, 2010
  • 21 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Apr 07, 2009
All you need to do is turn off your box, keep the TV set to the right input. Then unplug your power cable to your box and your video cable. Wait a minute, then plug the power cable back in, then the video cable, then plug it in to your TV. All you need to do now is power your xbox on. Simple.
Posted on Apr 11, 2010
  • xboxguruman Apr 11, 2010
    on. Simple.
5 Suggested Answers
SOURCE: xbox 360 flickers green and black on the screen
Back again. There is thread on CNET about this as well. My TV has made it's third trip to the repair shop, and Samsung is definitely aware of this problem on 4065F and 4665F LCD TV's manufactured in 2007.
I tried multiple cables and multiple input devices (XBox360 Elite, PC DVItoHDMI, and Scientifc Atlanta DVR with HDMI) all with different cables, all with the flickering.
The only known solution is to have the main board replaced (this should still be under warranty (1 year)) if not they still might replace it. It would cost about 250 in parts and 250 in labor.
If they do not install it correctly (since the boards come from factory and need to be adjusted) the picture will be too dark. Tell them they need to contact Samsung to get the instruction manual for board replacement.
I got my TV back and it has shown no signs of green flickering or signal dropping.
Posted on Jan 18, 2008
  • 1111 Answers
SOURCE: Xbox keeps freezing on the Microsoft Start-up screen
try clearing the memory cache
to clear the xbox 360's memory cache,
1. go to the system blade on your menu(should be the very last one)
2. go down to were it says memory, click on it. this should bring up your hard drive or other storage devices, press a on the one you want to empty
3. once youve gotten to the screen were it shows rename or format your storage device, input Y,X,X,LB,RB,X,X and a prompt will come up asking you if you want to empty your systems cache.
  • 4 Answers
SOURCE: My Xbox 360 won't play Xbox 360 games
run through your initial set up again.
Posted on Aug 19, 2008
SOURCE: i need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
@_@ Loco Xbox 360 Problem Guys I have no idea whats wrong with it. It's not playing any games. The laser reads CDs and DVDs flawlessly. The crazy part about it is that it DOES READ the games initially...
It seems your laser isn't reading the second layer on the games. Regular DVDs have only one layer of information, Xbox 360 games are "Dual Layered" meaning twice as much information in the same area. I would recommend buying a replacement laser from eBay and installing it yourself (as you already know how to take the Xbox apart)
Feb 17, 2011 | Microsoft Xbox 360 Console
Black screen from downloaded xbox classic game
DO ANY OTHER GAMES YOU HAVE DO THE SAME THING ?
Jan 14, 2010 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
My xbox would turn on but my screen will just be
Needs to be serviced. Solder under the GPU has lost contact. We can fix this for you. We are a listed repair service on this site.
www.videogamerepairservice.com
Apr 23, 2009 | Microsoft Xbox 360 Console
Black and white screen on tv when i play my x-box 360
Have you tried adjustign the mhz settings ie: change from 50mhz to 60 mhz as some games will show up in black and white if you have the xbox set to 50 mhz
Mar 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
No Screen on the Xbox 360.
i would help you but i have the same thing my did that to but my xbox show me colors then it whent to black screen and says to call xbox/support
Oct 19, 2008 | Microsoft Xbox 360 Console
Black screen
I had this same problem. What happened to me was that I mixed up the color coding on the tv cables. You can try to check if you did this. If not, call the help line on xbox.com.
Jan 13, 2008 | Microsoft Xbox 360 Console
Xbox 360
you ring microsoft, say you have 3 red lights (which you obviously dont have) and they take some details and you send it off and they send you a new one. Same thing happened to me, and thats what i'm doing.
Dec 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,064 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
